Quick Throttle Body Question
Old Aug 17, 2004 | 04:26 PM
Pretacopower's Avatar
Ok....I'm cleaning my throttle body right now by spraying the cleaner into the TB for 10 seconds with the engine off, and then starting it and letting it run for a minute. Then I repeat the process untill the can is empty. (This is how the can of TB cleaner says to do it)
My question is, my engine sputters and cranks for a long time before firing, right after I spray the TB cleaner. Is this normal? I dont want to induce any extra strain on the engine along with the TB cleaner if it's not supposed to be taking it.
Old Aug 17, 2004 | 04:36 PM
4RUNR's Avatar
Guest
The real way to clean it is take off the intake, take brake cleaner in left hand, and an old toothbrush in the right. I doubt your 1999 is gunked up in the intake, you can clean it of course if you are just looking to occupy the evening.
Old Aug 17, 2004 | 04:40 PM
Yeah but that Seafoam thread got me all excited so I decided it was time for some spring cleaning. Or fall cleaning rather....
Old Aug 17, 2004 | 06:03 PM
gwhayduke's Avatar
Yes it's normal. After you spray the intake, the mixture going into the cylinders is very rich. Cranking it gets rid of some of the rich mixture. Essentially you flooded the engine a little but with TB cleaner rather than gas.
Old Aug 17, 2004 | 06:21 PM
MTL_4runner's Avatar
Using a toothbrush is very important to ensure the TB is clean.....just spraying it in there will miss some of the carbon deposits. I use one hand to hold the throttle plate open and the other hand to scrub with the toothbrush.
Old Aug 17, 2004 | 07:39 PM
Thanks for the replies guys! Yeah, I didn't use a toothbrush but it sounds like a good thing to do. I can't find an extra one around the house though....maybe I'll just borrow my sister's
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
montanatruck
Feb 26, 2017 07:07 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
raiderhawks00
Jul 8, 2015 06:23 PM
