Aisin Manual Hubs
Old Aug 18, 2004 | 12:07 PM
Tyson94SR5's Avatar
Aisin Manual Hubs
Hello,
I was wondering what parts I might need to convert my 1994 Toyota Pickup with ADD front hubs, to the manual Aisin hubs I have been hearing about. I found a set at a junk yard, but I dont want to tear into it, and find out that I didnt get all of the parts that I needed to complete the conversion. I hear it is very easy to go from ADD to manual, but I thought I would ask here first. Thanks guys
Tyson
Old Aug 18, 2004 | 12:08 PM
superjoe83's Avatar
from what ive heard you just need the hubs, they bolt right up
Old Aug 18, 2004 | 12:20 PM
AKennedy87's Avatar
I know for pre 89 you need the spindle nut kit which is a 54 mm nut, a lock washer with bendy tabs to lock the nut in place, and then another 54 mm nut. These all go ontop of the wheel bearings.
Old Aug 18, 2004 | 12:26 PM
TRunner's Avatar
Sounds like you have all you need. The hubs...
The hardest part is rebuilding them to just make sure they are clean and that took me all but 90 minutes pokeing around at it. I could have done it in 30.
This link Will tell you all you need to do.
Old Aug 18, 2004 | 01:02 PM
AKennedy87's Avatar
Yea there is a few things that will help you out.
Cone washers suck and if you are removing them bring a hammer or a brass punch and pound on the metal part right behind the hub body. Undo the 12mm nuts but keep them and the washers on the end of the stud so the cone washers dont shoot back at you.
Also you can test them to see if they need a complete rebuild right away. When they are in your hand and in the FREE position, the inner hub should spin freely from the outer hub but whne they are in LOCK they shoudl be locked togther.
Pretty simple
Good Luck and they are deffinetly worth it
Alex
PS I am selling some right now but shipping to alaska would be a blow
Old Aug 18, 2004 | 03:35 PM
NCSU-4runner's Avatar
make sure you get IFS hubs and not solid axle hubs, they look exactly the same except for the knob which turns. One is flat across the top, the other extends beyond the surface of the hub slightly. Problem is i cant remember which is which, and im not at home to look on my truck
Old Aug 18, 2004 | 04:35 PM
superjoe83's Avatar
the solid axle has a bigger stub shaft, my friend got ifs hubs from a friend for his '83, and they didn't fit for that reason
Old Aug 18, 2004 | 04:49 PM
Tyson94SR5's Avatar
Conversion Kit or Not????
1994 Toyota Pickup SR5 4x4 5 speed ....Well I called around. One guy told me that I need a conversion kit for the ADD setup. Another guy was convinced that I dont need any conversion kit, he said all I have to do was bolt it on. I am wondering now. With the ADD setup, If I removed that plate and install the hubs without the conversion kit, would that do it?? They say I need the spindle bearing conversion kit??? Thanks for all the replies.
Old Aug 18, 2004 | 05:20 PM
Corey's Avatar
Co-Founder/Administrator
No such kit needed.
I have my ADD still intact, and the Aisin hubs will bolt right on.
For an explosive view of the hubs, see this PDF file.
Old Aug 18, 2004 | 07:16 PM
TheTank's Avatar
Yeah I have the ADD system too and wanted the Aisin hubs, so I just went to the junkyard and found 2 from an older 4Runner, cleaned them up. Unbolted the ADD hub, and bolted the "new" Aisin hubs right on. No conversion kit needed. They actually look pretty cool too. Very easy swap.
Old Aug 19, 2004 | 05:11 AM
TRunner's Avatar
Arrow
:pat: This guy is a idiot. You may call him back and tell him so.
This guy knows what he is talking about. Call him back and tell him so. Spread warm fuzzies, you know!?
You need the hubs and tools. That is all. Maybe a beer or two if your into that.
Old Aug 19, 2004 | 08:40 AM
Tyson94SR5's Avatar
Time to Rebuild hubs...Thanks a bunch for the posts..
Alright, I made a few phone calls. Well So I have this pair of stock toyota hubs for my truck now. They wanted 100 bucks for the pair. Anyways I might as well rebuild them before I try them out right? I got the .pdf file that has been posted in this thread so I think I can get it alright. Cant wait to get them installed now. Thanks alot guys. Ill see how it goes...
Old Aug 19, 2004 | 09:39 AM
TRunner's Avatar
Shop around... Toyota Parts Dude (search for him in here) will have them for less then that.
Old Aug 19, 2004 | 12:57 PM
leebee's Avatar
yes or no, remove the add system?
Originally Posted by Corey
No such kit needed.
hey corey
i think there is a write up on here somewhere regarding removing the complete add system and locking the shaft permanently. do i need to do that or can i bolt up the manual hubs leaving the add system intact? what would be the pros and cons of each set up? if i dont have to remove the add system and lock up the shaft, does it work like the old set up on my 86 runner where you just lock the hubs and shift the tc from inside? any help would be greatly appreciated. thanks in advance.
lee
Old Aug 19, 2004 | 03:41 PM
Tyson94SR5's Avatar
lee
I bought those hubs from the salvage yard today. I need to get new gaskets thought, the mechanics there trashed the originals when they took the hub off. Anyways, I notice that the hubs are fairly tight ( hard to get from locked to free) . Will taking them apart and greasing it all up again make it any less tight? Anyways I get my question here is, what does the "rebuild" consist of? Just take apart and regrease all pieces? oh lee, I am going to just leave the rest of the ADD system on the truck. Should be ok. Just have to remember to get out and lock the hubs from now on Thanks for the replies everyone. Helped me out alot.
Old Aug 19, 2004 | 05:32 PM
"Cat-O-Leen"'s Avatar
This is a good thread. It talks about the parts you'll need to rebuild and grease them up.
https://www.yotatech.com/forums/show...t=aisin+gasket
Old Aug 19, 2004 | 06:54 PM
4RunnerKid's Avatar
I want to put a pair on mine too as soon as I can, so maybe I should pay attention to this thread... So they really are an easy install???
Old Aug 19, 2004 | 07:30 PM
Corey's Avatar
hey corey
lee
You do not need to do anything other than bolt on the manual hubs.
With the ADD left, what you have to do is lock in the hubs of course, then throw the 4WD lever into 4 low or 4 hi.
But...you have the best of both worlds.
You can leave the hubs locked in while driving to the off road course, or during crappy weather in the winter.
When you need 4WD, you can "shift on the fly" just like before, up to 50 MPH I think.
For the part #s for the gaskets, please see my personal website listed in my sig below.
Look in my mods section.
For install info, please read the Tech section here @ YotaTech.
Just follow the info.
Old Aug 19, 2004 | 10:19 PM
AKennedy87's Avatar
A few things:
1) Maybe you should have removed them yourself so you coulda figured out how to take your old ones off, the gaskets woulda been good, and it woulda been cheaper.
2) You really dont need the cap gasket, if you are doing a lot of water just silicone it unless you are doing water than going in freezing temperatures (You are from Alaska right). The guy at Toyota told me that he has frozen hubs before when the water freezes and he poored a hot coffee on it and heard the little ball click to engage it.. Get the HUB BODY gasket though.
3) Take apart the switch and sand down the ring where it attaches to the middle part a little bit. This will smoothen up the turn, but dont loose the spring or ball when taking this apart.
4) You dont really need to do a full rebuild either, mainly an inspection. Make sure they engage correctly and check all the snap ring's you see. Also check the spring on the cap. These are what usually break. Than just put a nice layer of greese on everything else and they will work like a charm.
5) Paint em to make em look pretty.
This is kinda my process when I do them so give it a shot.
Good Luck,
Alex
P.S. - I still have some for sale for all looking.
Old Aug 19, 2004 | 11:30 PM
914runner's Avatar
Once you have the hubs on, you can dissable the ADD permanently to elminate a possible falire of the ADD actuator system.
