wheel spacers
Old Aug 17, 2004 | 08:15 PM
alexander's Avatar
wheel spacers
hi!
does anyone know where can i find 1/2 inch wheel spacers for 00 4runner??
i spent a couple hours online,and coudn't find it
Old Aug 17, 2004 | 08:46 PM
jimbo74's Avatar
if only looking for half an inch, your only option is the slide on kind and those just straight suck! they can cuase major damage and over time eat through the wheels studs and cuase a wheel off scenario.... why do you want spacers in the first place? if the tires rub, i would suggest smaller tires or different wheels rather than risk it with the spacers
Old Aug 18, 2004 | 04:01 AM
alexander's Avatar
no they do not rub. it's for the look only.I've just instaled new BF 265/75-16,and now it does not look right. so i thought maybe wheel spacers would help. and now after reading several posts about it on this forum,i gues i'm just gonna leave this "bad idea".
any whay....Thanks Jim
Old Aug 18, 2004 | 04:04 AM
92 Toyota's Avatar
Why do you think slide on wheel spacers suck?What major damage can they cause?I've had 1/4" spacers on my truck for over 12,000 miles & have had no problems.I don't think I would double them up(for 1/2") though because of no lug thread left.
Old Aug 18, 2004 | 04:08 AM
alexander's Avatar
did they make noticeable diference??
Old Aug 18, 2004 | 04:22 AM
92 Toyota's Avatar
No it didn't look differant at all,I just put them on to keep the wheels I had from rubbing on the brake caliper.
Old Aug 18, 2004 | 07:24 AM
Flamedx4's Avatar
I had 1/4" spacers on the front of my 85 (to keep the wheels from rubbing - actually the wheels didn't rub but the weights did) for about 150k and never had any trouble. But 1/2" would probably be too much, it would strain the lugs and leave too little threads to bite safely.
Old Aug 18, 2004 | 11:14 AM
deathrunner's Avatar
I will be running 1 1/2 or 2" spacers on the rear to match my front width. But the ones I want are not slide ons. They actually use the xisting studs to mount the spacer, then the spacer presents new studs to mount the wheel.
I saw them at protrux www.protrux.net
Old Aug 19, 2004 | 01:30 AM
jimbo74's Avatar
the ones that are made properly like the ones above that deathrunner speaks of is fine.... not sure if my whole post was read before, but i work as a tire tech, that said i touch more tires per day than most people will ever touch in their lives... i have seen on probably about 10 differnt vehicles that the slide on spacers have eaten through the studs, and cuased a wheel to fall of the car on the road... thats jsut scary and in my opinion i wouldnt take that chance....
Old Aug 19, 2004 | 06:25 AM
4RUNR's Avatar
Guest
Someone doesn't need to be a tire tech, or claim to be one to make a logical conclusion about something. Spacers can not "eat" through a stud. Saying something does not make it true (unless of course you can convince us somehow with an explanation that passes the common sense test).
Old Aug 19, 2004 | 08:11 AM
BajaRunner's Avatar
Alexander, here is a link to some nice wheel spacers:
http://www.allprooffroad.com/wspacers.htm
1.5" though...3" of total width...sheesh.
Old Aug 19, 2004 | 08:45 AM
Flamedx4's Avatar
Here's another way to do it.
http://www.sky-manufacturing.com/suspension2.htm
Old Aug 19, 2004 | 09:19 AM
92 Toyota's Avatar
I'm not questioning your experience, but how could a aluminum spacer that is pressed tight between a rotor & wheel eat through wheel studs that are much stronger steel?
punks_is_4x4
Aug 21, 2015 01:35 PM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
Yotoder865
Jul 9, 2015 07:51 PM
