1993 4runner Headgasket Or Two Blown
Old Aug 14, 2004 | 04:35 PM
Dbreher's Avatar
I have a 1993 4Runner with a blown head gasket. I filled it up with water and few minutes later had white smoke pouring out the exaust like a fumigator. I have never done a head gasket on a 3.0 but have done many on other motors. Is there anything I should look out for. Also how hard is it to do and roughly how long to do the job.
DON
Old Aug 15, 2004 | 09:49 AM
nunsa's Avatar
DON
They really are not that hard to do if you take your time. Here's some advice I always give to anyone doing a HG on a 3.0 = REPLACE your knock sensor & wire, let me repeat that: REPLACE your knock sensor & wire! I 've seen it all to often when we'd did those HG recalls and a week or so would go by and the truck/4rnr would come rolling back in w/a code for a knock sensor!
I don't know how many miles you have on this truck but check with your local Toy dealer, it might be under warranty yet! 1990> and the truck can't have over 100,000 miles on it! So, if your truck don't have 100,000 on it, guess what? Toyota will replace it for free!! It's called the V06 Campaign!
In the event that you have to do it yourself, get your heads redone. Another tip I give people is when you pull the head bolts out, take them and put them into a piece of cardboard, that way you will know exactly where the go when it comes time to put her back together and a camera helps also!
* Good Luck Don!
* Harry *
Old Aug 16, 2004 | 12:18 PM
934rnr's Avatar
Yes you too can rebuild your 3VZE in the comfort of your own living room.
Also don't believe the hype on having to have the DOA studs one guy on here has gone through that hell already. Just get some replacement OEM headbolts if you aren't reusing the old ones. Yes I second the knock sensor wire as well I should have done mine.... Oh well...
Charecter1
Nov 6, 2023 10:08 AM
sandyota
Feb 4, 2021 11:16 AM
Colington
Mar 8, 2020 09:51 AM
Jdgarrison
Oct 1, 2015 05:22 PM
colinmil
Jul 6, 2015 04:03 PM
