Yet another OME rear install question
Old Aug 17, 2004 | 11:35 AM
GreenRunner's Avatar
Alright, I'm getting ready to install my SAW/OME install this weekend on my 98 Limited 4Runner and from looking at the OME components, I realized there are no instructions. Not to fear as there are many write-ups on the matter. I haven't gotten underneath the vehicle yet to see how everything is set up, but can anyone tell me how all the bushings and washers go together on the N86/N86C shocks? There's 2 flat bushings, 4 steel flat washers and an hourglass shaped bushing (I think that's it). I'm sure I could probably figure it out once I get under the vehicle, but I wanted to go in prepared.
Thanks for any help!
Old Aug 17, 2004 | 11:48 AM
loosehead's Avatar
The ID of the bushings and washers will tell you which ones go on top (stud-mount) and which ones go on bottom(the eye-mount on the axle). Without over-stating the obvious, just pay attention to how the old shock come off the truck and then install the new ones "in reverse order", and you'll do fine.
bamachem's Avatar
(edit) and to overstate the obvious:
For the top, put a washer onto the stud, followed by a pancake bushing, then install the top stud into the upper shock mount, then put the other pancake bushing onto the stud followed by a washer and the nut and tighten.
Cut the hourglass bushing in two (across the skinny part) to make two do-nuts. Put a washer on the lower shock stud, then half the bushing, then the lower shock eye, then the other part of the bushing, then another washer, then the factory retaining bolt and tighten.
Old Aug 17, 2004 | 11:52 AM
loosehead's Avatar
Originally Posted by bamachem
(edit)
I didn't cut the hour glass shaped one, just used a little grease on the outside of it and on the inside of the shock eye and pushed the bushing into the shock, then put it on the axle stud sandwiched b/w the washers. Not saying that cutting it is wrong, just not necessary.
Old Aug 17, 2004 | 12:05 PM
waskillywabbit's Avatar
Talking Ome
My OME stuff came with some simple diagram instructions, so look again if you bought your stuff new. Otherwise...
CLICKY
Good luck!
Old Aug 17, 2004 | 12:06 PM
XtremeOff-Road's Avatar
As far as the springs are concerned, if you receive two different length coils, ensure the longer of the two goes on your drivers side. Disregards any tags on the coils that indicate driver or passenger side.
Mike
Old Aug 17, 2004 | 12:14 PM
bamachem's Avatar
^^^ Absolutely agree w/ that one.
Old Apr 29, 2009 | 01:09 PM
DeMented Toys's Avatar
Wish I would have read that about an hour ago!
Old Apr 29, 2009 | 02:27 PM
CHSrunner's Avatar
Whoa!! old thread... at least you used the search function. But another tip is spray the bushing with some wd-40 or pb blaster and put the lower shock over it and hit the top with a hammer or maybe even just push really hard. It'll slip right in presto you're done.
Old Apr 29, 2009 | 04:19 PM
Yeah greasing it up was mentioned above too. I just couldn't find any lube. I ended up finding some wheelbearing gresae and used that to slide it in.
bigjstang
Jun 2, 2025 03:56 PM
Road Bull
Oct 10, 2015 04:55 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
