Window help
Old Aug 12, 2004 | 10:31 PM
Kallel's Avatar
Window help
took off power window console and I am positive I put it back right but now nothing works and my back left window went down and doesnt go back up now...what could of went wrong?
Old Aug 12, 2004 | 10:36 PM
98whtLmTD's Avatar
Does the window go up from the master controls (driver seat)?
Old Aug 14, 2004 | 06:53 PM
Kallel's Avatar
The master controls is what I took out....ON the driver's side door...Took it apart and put back together when I plugged it back in passenger window on driver's side went down and then would not go up...no other windows worked and the auto locks didn't work either...
Can I reset the circuit breaker?
Old Aug 15, 2004 | 08:03 AM
Sludge's Avatar
I would pull it back apart and check your connections. Also if you have a volt/ohm meter you can check the connections that way.If still no luck with the switches(same problem with my moms camry) to get your window back up just pull the door panel and use a battery or some sort of 12v source(I had a 12v power supply) and connect it to the window motor and it will go up or down depending how you hook up the power.
Old Aug 16, 2004 | 03:41 PM
Kallel's Avatar
I tried checking power...only got juice on door lock..Pannel is out, should door lock on passenger side work? (because it doesn't) and as I said before the panel doesn't work anything now, should I still be able to work other windows with their individual window button? (because I cannot do that either)
Where is the circuit breaker in 91 4runner? can't find it.
Old Aug 16, 2004 | 07:57 PM
Sludge's Avatar
As far as circut breaker i dont know of one but did you check the fuses in the kick panel area by your feet on the left side.Also if i remember correctly when that master switch panel goes out so do the other switches in the door.
Old Aug 14, 2006 | 12:06 AM
zesnowbr's Avatar
Heav you guy figured this one out?
i'm having the same problem and i can't fix it
Thank's
Old Aug 14, 2006 | 12:14 AM
marko3xl3's Avatar
If this helps anyone, my passanger rear window switch went out a while ago and by disassembling it, I found out that somewhere along the line, a short occured because I found black residue on the switch contacts in the guts of the switch.
After some cleaning, it worked like new. You just have to be very careful taking it apart because if you break the switch, you won't be able to put it together. Don't ask me how I know.
RDubya
Feb 10, 2017 04:46 PM
PNW94Runner
Sep 29, 2015 02:55 PM
tazman1972
11
Sep 28, 2015 10:32 PM
punks_is_4x4
Sep 19, 2015 05:52 AM
mat
Sep 17, 2015 11:18 PM
