PCV is easy, my eye!
Old Aug 13, 2004 | 07:47 PM
Tacoma Dude's Avatar
Angry PCV is easy, my eye!
Okay maybe I'm just not pulling on the right thing but I went out to change my PCV valve and it would NOT come out!
This is for a 22RE - I just want to clarify that the PCV is on top of the valve cover towards the back (closer to the cab)? And the tube is connected to the EFI, right? The location doesn't seem to match up with my Haynes manual.
Why won't the dang thing come out?!?!?
Old Aug 13, 2004 | 08:13 PM
shazaam's Avatar
my pcv takes about 3 seconds to change ... ha ha
Old Aug 13, 2004 | 09:00 PM
AKennedy87's Avatar
Likewise
Old Aug 13, 2004 | 09:48 PM
bah... you guys suck!
Yours is a simple pull out? Mine is like wedged in there!
Old Aug 13, 2004 | 09:55 PM
shazaam's Avatar
takes a little twisting motion
Old Aug 13, 2004 | 10:10 PM
cabbage's Avatar
Did you use a plier? Arent there two PCV valves on our 22re's? The manual only points out the one by the oil cap...
Old Aug 15, 2004 | 10:25 AM
nunsa's Avatar
That's nothing! You ought to try the 3.0 PCV
It's stuffed under the intake and 9 time outta 10 the grommet is stuck to the valve and dried out! Long pair of needle nose pliers, elbow grease, patience is what you need! :cry:
* Harry *
Old Aug 15, 2004 | 02:52 PM
tallboy's Avatar
Gromet needs to be replaced
Is your PCV grommet is as hard as a rock from engine heat? It can frustrating if that is your problem. Yes your location is correct. Grab the valve with some plyiers and work side to side in an 360 motion and pull up at the same time. It should come out.
Greg
Old Aug 15, 2004 | 02:57 PM
WolfpackTLC's Avatar
You're holding your mouth wrong...
It should only take a pulling motion and a little twisting...
Old Aug 16, 2004 | 03:16 PM
I was getting frustrated enough to start using my teeth
I'll have to give this another try tonight. Thanks guys!
Old Aug 16, 2004 | 03:20 PM
seaflea's Avatar
Youre probably gonna have to get a PCV puller.
They sell em at... well I forget now. maybee someone can loan you one
Actually I had problems taking mine out once and it turned out too be the Rubber gasket on the valve cover. It was hard as a rock. After I got it free I was able to get a new gasket. Havent had the problem since.
Old Aug 16, 2004 | 03:29 PM
Yeah, the gasket was giving me some hassles - I was wondering what the cost of replacing that might be. I'll have to see what kind of troubles I have when I get home.
Old Aug 16, 2004 | 03:37 PM
seaflea's Avatar
The grommet shouldn't cost more that about $3.00 to replace. That price is from my local parts store. The stealership may bit a bit higher.
Old Aug 17, 2004 | 08:29 PM
That's good to hear. I gave it another try again today and the stupid thing wouldn't come out. I would have used my mini pry bar to get the gasketing off but I wasn't at home and barely had any tools with me
Quick dumb question...
Is the engine supposed to stall out when the PCV hose is disconnected?
Old Aug 18, 2004 | 02:45 AM
seaflea's Avatar
Mine stalls out any time I unplug it. So, I would say Yes.
Old Aug 18, 2004 | 08:52 AM
PirateFins's Avatar
Yeah the engine will stall, because you are loosing vacum big time. My Pcv was just as stuck as what you are descibing but I got it out. Just tool brute force.
Tried and true method to removing a stuck 22RE pcv valve. Grasp pcv with locking vice grips tightly. Put a screwdriver handle, on top of valve cover and under the vice grips, to use as a lever and push down on the vice grips and try and pop it out. You can also tap on the vice grips with a hammer to try and force it up and out.
OR lastly, (not recomended for obious reasons) Stand on a ladder and jump up & down on the vice grip handle as hard as you can while maintaining your balance on the ladder (have someone inform 911, before starting this procedure).
Old Aug 18, 2004 | 11:13 AM
Okay so if the engine will stall with the PCV out where is the best place to put in some Seafoam? I just picked some up yesterday but can't find a good place to introduce it into the engine...
Old Aug 18, 2004 | 11:36 AM
superjoe83's Avatar
you can prop the throttle slightly open to about 1000-1200 rpm by sticking something between the throttle stop screw it shouldnt stall at that rpm
Old Aug 18, 2004 | 11:46 AM
Okay so I understand let me recap:
so if the throttle is open the removal of the PCV won't stall the engine?
Old Aug 18, 2004 | 11:54 AM
superjoe83's Avatar
no guarantees, but it will greatly reduce the possibility, the rpm will still drop, but not enough to stall it
