What is the biggest 18 inch A/T tire that I can fit?
Old 08-13-2004, 09:43 AM
Scarface's Avatar
I have a 2000 Limited 4wd 4Runner and am about to purchase some Enkei RT6 18 inch wheels and want some A/T tires on them. What is the bigges I can go without any major rubbing issues without having to do a lift? Thanks in advance!
David
Old 08-13-2004, 11:12 AM
User 051420's Avatar
Using a metric to english calculator..I can see 275/65/18's fitting. Thats about a 31.5x11.5. Tirerack says 285/55/18. I don't see any decent tires in either sizes. This tire seems to look best.
Check out a tire shop and see what they can fit for you.
Old 08-14-2004, 04:39 AM
Scarface's Avatar
Thanks for the help, I appreciate it. I have a local tire shop that I am going to talk to on Monday, and then hopefully I can get this thing rolling soon, again thanks!
Old 08-14-2004, 08:22 AM
UNR.Grad's Avatar
Actually a 275/65/18 is not a 31" tire. That is way more on the lines of a tall 32, almost 33" tire. Unless you're lifted there's no way an 18" tire with a sidewall of 65 will fit.
Old 08-14-2004, 09:13 AM
Xx 4Runner xX's Avatar
I think those would be bigger too. The 255/70/16's i just put on are taller than the 31x10.50's i just took off.
But the Michelin 255/70r16 my dad has, and the 31's i had on there, were the exact same height and width, if that helps.
Old 08-15-2004, 10:08 AM
RalleRunner's Avatar
I didn't know the Wrongler AT comes in 18's....
But the BFG all-terrain does come in that size.
Old 10-14-2004, 10:50 AM
Citykid's Avatar
Scarface, what happened?
Old 10-14-2004, 07:00 PM
Scarface's Avatar
I decided to hold off, at least until I am back from my trip, I think when we get back I am considering the Enkei deep six 20 inch with tires, if it is too costly then I will probably opt for the 18 inch wheel/at tire combo. I don't take it off road much since my wife drives it primarily, but I still would like the at tire on the 18 just in case I go that route...
Old 10-14-2004, 08:06 PM
Citykid's Avatar
I've decided to go with either Bridgestone Dueler H/P or Bridgestone Dueler HL Alenza in 285/60-18.
Old 10-15-2004, 06:15 AM
Scarface's Avatar
Do you have any pics of a 4 runner with that size tire on there? Will the 285 rub any? If not then i would like to go with a 285...I also thought about just keeping the stock 16's and going with a nice a/t 16 inch tire but don't know what would be good to go with.
Old 10-15-2004, 08:35 PM
FilthyRich's Avatar
If you go stock, then use the trusty Revos
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
rondogracing
Engine Swaps
16
08-24-2015 03:02 AM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: What is the biggest 18 inch A/T tire that I can fit?
