Alternate method for replacing steering rack bushings
Old Feb 28, 2012 | 02:44 PM
opie74's Avatar
2001, v6, 4wd, auto
So I crawled under the truck today to get the bushings swapped out. Got all the bolts off the rack and went to remove the drivers side tie rod and could not get the bugger out. I did not want to mess it up because it is not bad and I do not want to replace a good part. So I hemmed and hawed for a bit and it hit me.... With the rack free, fire up the motor and crank the wheel to the left. The rack moved towards the drivers side and from there I was able to pull it rearward and get everything done.
Old Feb 28, 2012 | 03:11 PM
aowRS's Avatar
I presume you were looking to remove the tie rod since the truck was not in the air? I've done this job twice without touching the tie rods.
Andreas
Old Feb 28, 2012 | 04:19 PM
opie74's Avatar
Correct, I drove up on some ramps, but did not have the front jacked up.
BushPig
Oct 29, 2022 06:26 AM
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
andrewtexas123
Jul 14, 2015 04:29 AM
colinmil
Jul 6, 2015 04:03 PM
