LC engineering headers not fitting right on my 3rz
Old Feb 4, 2012 | 06:29 PM
RB4runner's Avatar
I finally get around to changing exhaust manifold with LCE headers at a local shop. And realize it was a good thing, because the stock manifold had developed a big crack in between cylinders 2 and 3. I get the LCE header connected to the EGR pipe. As I am trying to fit it on the engine block, I notice the lower part of the header is hitting the sway bar mount. I can only get it on the back studs and about an inch more left to go on the front ones. It still needs to swing a bit more to fit properly on to the engine block. But it is hitting the sway bar mount. I just need a 1/2 inch or more of clearance to make it fit. I can't grind down the sway bar mount without relocating it. My only theory is that when they were making the header the angle is out of spec. Causing the header to come out to far and thus hitting the sway bar.
This happened Friday around 6pm and I cant get a hold of LCE until their calling hours on Monday. Did anyone run into any problems with their header install or am I doing something wrong? I made sure I ordered the right part for a 2wd 3RZ 4runner.... Any advice?
I wish I took pictures, but it was late and I was not happy with the results at all and called it a day. Having to leave my 4runner at the shop..
I searched and saw no other threads about anyone else with a 3rd gen 4runner having this problem. Sorry for the few post I have. I have been searching and finding answers more than posting.
Old Feb 5, 2012 | 01:56 PM
NwRunner's Avatar
I was looking at getting LCE headers for my Taco and remember them not being available for 4Runners. Maybe for this reason?
From LCE-
"LCE 2RZ/3RZ header kits are direct fit on single catalytic trucks only."
Old Feb 9, 2012 | 05:19 PM
FrankM23's Avatar
header
the headers fit but the cat and header are one piece. In tacomas I believe it's two pieces. I've got a 4runner with the same header I didn't have a problem with the sway bar. I did have to cut the mount for the old header but that was it. Keep messing with it. It might just be your angle. I thought it was super awkward when making it fit but that's just me.
Old Feb 9, 2012 | 05:38 PM
87yoter's Avatar
had to remove a protecter plate to fit lc header on a 22re worked lot more power but was a pain to get off...
Old Feb 9, 2012 | 06:04 PM
dropzone's Avatar
Fossilized
What did LCE say when you contacted them?
Old Feb 9, 2012 | 07:06 PM
87yoter's Avatar
this was on an auto but it came with a note that suggested removing the plate and it needed to be done. got at least 15 to 20 hp with sraight through cat and magnaflow muffler + 2 1/4 pipe can go up hills now in drive at fifty beats 2nd and 35...
kazuya2416
Apr 5, 2024 02:17 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
icentropy
Jul 9, 2015 02:12 PM
wilbertd
Jul 6, 2015 07:39 AM
