What's this connector on front timing cover
Old Feb 28, 2012 | 11:50 AM
vasinvictor's Avatar
Where does this connector come from and go to? I hope it has something to do with my awful running 3.4 I've swapped in.
Second pic is my motor. First pic is a stock photo of the wire I'm missing.
Old Feb 28, 2012 | 12:04 PM
habanero's Avatar
TPS, I think, but don't quote me. I do know they don't run too well if at all with that uplugged. Wiring harness on top and in front of the engine, just behind where the plug wires can be seen.
Old Feb 28, 2012 | 12:09 PM
My TPS is plugged in. It's at the top of the motor, on the throttle body.
Old Feb 28, 2012 | 12:14 PM
habanero's Avatar
Ah...I couldn't remember what the thing is called that that plugs into. That makes sense it's not the tps given where it goes. Should've thought harder on that. Crank sensor? I am sorry I can't remember. I am sure about the rest of it. Can take pic if you want.
Old Feb 28, 2012 | 12:15 PM
Yes a picture of where it routes to/from would be cool.
Old Feb 28, 2012 | 12:17 PM
habanero's Avatar
Ok, give me some minutes...
Old Feb 28, 2012 | 12:22 PM
mt_goat's Avatar
Camshaft position sensor
Old Feb 28, 2012 | 12:25 PM
Thanks Goat. An unplugged camshaft sensor will surely cause my horrible running! Now the problem is that I can't find any wires that aren't hooked up. Hopefully a pic will help.
Old Feb 28, 2012 | 12:29 PM
mt_goat's Avatar
The wires should come from near the top of the timing cover on that same side.
Old Feb 28, 2012 | 12:36 PM
habanero's Avatar
Thanks Mr. Goat! Gonna remember that someday...
Follow the pink wire...pics from the plug to where it goes in the harness. The other part you can see on your engine pic, behind the timing cover.
Old Feb 28, 2012 | 12:38 PM
OK, I have the top part the goes to the top of the timing cover. I'm missing the bottom wires. The male connector.
Edit: First picture wasn't my motor. The connector shown on that picture is the one I'm missing. I'm going to post a pic of what I have.
Old Feb 28, 2012 | 12:43 PM
What I've got.
Old Feb 28, 2012 | 12:45 PM
mt_goat's Avatar
You might need to buy a whole new cam position sensor since the connector comes on that.
Old Feb 28, 2012 | 12:47 PM
Oh dern. This motor came straight out of a '98 and into my '95. I haven't taken it apart whatsoever. I can't imagine why the camshaft position sensor would be missing.
Old Feb 28, 2012 | 12:57 PM
mt_goat's Avatar
Or you might find a used one in a bone yard...maybe someone found your's and bought it LOL.
Old Feb 28, 2012 | 03:14 PM
rworegon's Avatar
The Camshaft Position Sensor Assy P/N 19300-62010 is about $106 + shipping from the online Toyota sources and just the sensor is $88+ 90919-05021 (sensor without the mount, it appears):
http://www.utoyot8.com/Picture.aspx?...ccode=&ppName=
http://www.toyotapartseast.com/Page_...3556,3557,3558
Old Feb 28, 2012 | 03:38 PM
thanks dudes.
Old Feb 28, 2012 | 05:36 PM
enapa's Avatar
Just look behind cover. See if the sensor is there.
Old Feb 28, 2012 | 06:55 PM
revenantdead's Avatar
what enapa said...
Old Feb 28, 2012 | 06:58 PM
I will I will! In the morn. I'm positive it's there. I'm also positive that I've managed to yank the wires out by accident during the swap. Hopefully they can be repaired. I'll update in the AM
