99 4runner hard to crank especially when cold
Old Jan 20, 2012 | 09:59 AM
sideshot61's Avatar
We have a 99 4runner (2wd w/ 4cyl engine, 210K) and have two problems which I do not know if they are related. - This vehicle has suddenly become very unreliable about starting up, particularly when cold. Turns over fine; then sputters and puffs white smoke over and over, but will FINALLY catch up and then run FINE. After this initial start up and while still warm it cranks ok; most of the time.
We have cleaned MAF sensor and removed the throttle body and cleaned it,also replaced fuel filter (which was dirty). It almost seems like it has jumped time, but if so then it would'nt run like a top after finally cranking?? Also, it tends to sporadically run hot. No water in oil and vice versa. I am at wits end, any and all suggestions will be greatly appreciated.
Old Jan 20, 2012 | 12:00 PM
enapa's Avatar
Sputtering when first starting along with running hot points to a blown headgasket. Get it tested for exhaust gases in the coolant.
Old Jan 20, 2012 | 01:04 PM
sideshot61's Avatar
headgasket?
Thanks, I hope it is maybe something else, because it runs great and seems to have plenty of power.
Old Jan 20, 2012 | 04:01 PM
enapa's Avatar
Yeah mine ran great and had plenty of power. But it had same symptoms you have. I hope im wrong, but get it checked.
Old Jan 21, 2012 | 12:43 AM
wyoming9's Avatar
Red face
When was the last time you gave it a good tune up??
Changed the Air filter??
How cold is cold ??
It is normal to smoke some on cold starts .
Head Gasket if your blowing white smoke then your coolant level will drop has it??
I don`t know enough about these engines .
Do they get air pockets??
Have you done a pressure test on the cooling system??
Has the timing belt ever been changed
Old Jan 21, 2012 | 05:23 AM
sideshot61's Avatar
When it runs hot it sometimes blows out coolent through the cap on the overflow tank. The top hose will sometimes collapse. The 4cyl has a timing chain, so I don't think thats it. As for the start up: when it cranks it does so in 2-3 sec.s of engine turnover; when it won't, we usually have to hook up jumpers for enough juice to keep it turning while manipulating the acc. pedal till it finally stops sputtering/popping and catches up. Thanks for the reply.
bigjstang
Jun 2, 2025 03:56 PM
skoti89
Jul 8, 2015 12:05 AM
bryan34w
Jul 6, 2015 05:53 PM
coryc85
Jul 6, 2015 04:07 AM
