Power Steering Pressure Hose
Old Jan 27, 2012 | 03:09 AM
MarkT's Avatar
Has anyone replaced their Power Steering Hoses?
The Pressure side has a banjo bolt on the pump side. I cant tell if the leak is coming from the pressure or return line; but think it is most likely the pressure line near the rack, but at 140K miles probably should replace both.
The hydraulic fittings for both the pressure and return lines on the Rack looks to be nearly impossible to get to without dropping the whole Rack?
OEM/Aftermarket part numbers for the pressure line?
Thanks,
Mark
Old Jan 27, 2012 | 07:18 AM
Sensei's Avatar
Ask your local auto parts store / stealership
Old Jan 27, 2012 | 04:00 PM
MarkT's Avatar
Power Steering Hose
Well NAPA has a pressure side hose (part number 72966) for about $93.00.
I found the same hose on Rock Auto; it is made by Edelmann (part number 80269 for about $65.00. Only problem is it does not look like the OEM hose; the fittings look right; 16 MM Banjo with switch port on pump end, and 16 MM Male flare on rack end, 32.5" long. But it does not have the hard line; that functions as a cooling portion in front of the frame. It is hard line to pump; then hydraulic hose to the hard line portion at the rack.
The OEM pressure line is hard line to hydraulic hose to hard line (in front of frame) to hydraulic hose; then back to hard line again at the rack fitting.
Has anyone replaced their OEM line with the Edelmann/NAPA line?
http://www.rockauto.com/catalog/rafr...0-80269-298936
Old Oct 16, 2015 | 01:42 AM
jtea's Avatar
High pressure PS hose
YES, I tried the Edelmann hose. It is grossly dissimilar to the OEM part.
Vendor did give me a refund, thankfully!
JTea
jbv808
Aug 6, 2021 04:47 PM
the1998sr5
Jul 16, 2015 06:20 AM
88yodabasket
Jul 13, 2015 01:32 PM
jon.r
Jul 11, 2015 03:34 PM
skoti89
Jul 8, 2015 12:05 AM
