4runner rear control arm bushings
Old Mar 19, 2012 | 08:30 PM
narfy's Avatar
forgive me if this has been asked before... i searched and didn't find much...
has anybody ever replaced rear control arm bushings on their 3rd gen 4runner? my 97 LTD upper (shorter) doggy bones have the bushings pushed to one side and the arm is about to contact the frame as a result. i guess torque and time just pushed it over. anybody know if there are any aftermarket bushings available? i know toyota does not make them for the uppers. they require you to replace the arm.
i know 98+ have replacable lower rear control arm bushings, but they do not list them for the 97. does anybody know if they fit?
Old Mar 20, 2012 | 04:38 AM
aowRS's Avatar
I would think that any of these suspension components are interchangeable between all 3rd 4Runner models (1996 - 2002).
Andreas
Old Mar 20, 2012 | 08:59 PM
narfy's Avatar
interchangable, yes... are they the same tho?? kuz the toyota parts catalog lists the rear lower control arm bushings for 98-02 only, and excludes 96 and 97...
Old Oct 7, 2012 | 04:47 PM
mikeleach's Avatar
It's the same bushing in the lower and upper rear control arm. I'll cut and past from autopartsway.ca
Weight: 0.45 lbPackage Size (W x H x L):1.80 x 1.80 x 2.50 inchesPosition: Rear Lower Minimum order quantity:1Leaves Warehouse by:9:30PM EST MondayRequires two per arm
Product Notes: / Rear Fits lower or upper control arms, requires 2 per arm.
Old Oct 8, 2012 | 08:05 AM
KZN185W's Avatar
Please note that there were changes in the lower control arms in the 2nd half of 1996, then in the 2nd half of 1997.
For 1996 to mid 1997, the bushings of the rear lower control arms are captive to the rear control arms. from mid 1997 to 2001, the bushings for the rear lower control arms are replaceable.
the bushings for the rear upper control arms are captive to the control arm.
Old Oct 8, 2012 | 10:04 AM
mikeleach's Avatar
Thanks for the info regarding captive bushings. I have to replace the lower control arm bushings and was going to do the upper at the same time. I guess I better order the whole arm.
Old Oct 9, 2012 | 02:08 AM
KZN185W's Avatar
Since you're replacing the lower control arms, I would recommend that you get the ones with replaceable bushings. These bushings provide more flex compared to the captive bushings.
HTH
Old Nov 27, 2012 | 07:18 AM
Performance1's Avatar
Rear Lower Control Arm drama
I JUST had my rear lower control arm bushings replaced after a long (and pricey) road to today. Here's what happenned:
After noticing a fair amount of twitchy swaying on the highway, discovered
that my factory arms had very worn/torn bushings. Decided to do an "upgrade" and look into some beefy aftermarket lower arms. Goals were to eliminate the rear wander and ideally pickup some additional wheel travel/articulation. Considered two options (Total Chaos arms were too pricey):
1) Sonoran Steel's http://www.sonoransteel.com/index.ph...108cf2653afd00
2) ToyTec's http://www.toyteclifts.com/index.php...mart&Itemid=72
Went with ToyTec's mostly because Sonoran's arms just seemed like a beefier stock version (because they use the same stock bushings). Almost immediately noticed that the ToyTec arms seemed to "clunk" over bumps; found this VERY annoying. So annoying that I went ahead and had new bushings pressed into my stock arms and swapped out the ToyTecs for rebuilt stock arms. (bushings are Toyota Part# 48702-35070)
In retrospect, I should have just bought the Sonoran Steel rear lower control arms Day1. Would have saved me much time/money/aggravation. Not sure if anyone else has had the same noisey experience with the ToyTec arms or not... my truck lives 50% of the time offroad... that might be a factor.
For 1999 4Runners, anyone know what options exist for replacing the rear upper control arm bushings? Are just the bushings available? Same part # as the lower bushings? OR, only option is to buy the entire arm? (After my recent lower-arm experience, I'm only going to go with stock bushings)
Old Feb 27, 2014 | 08:21 AM
mrtojo's Avatar
re: bushings
Just ordered replacement bushings for upper and lower control arm,. From febest. G oing to use a giant c-clamp to put in new bushings maybe a pony clamp with socket and flat bar. PIA ordering from them tho dropped my call 4 times. Wanted the fomplete arm assembly with bushings they say don't have don't want to pay roca price dor single arms. Definitly pictires
Old Mar 6, 2014 | 09:22 AM
mrtojo's Avatar
Sitting with the parts in front of me. Rear lower control arm bushings are larger than the uppers. Not the same size
Old Mar 8, 2014 | 03:18 AM
KZN185W's Avatar
the bushings for the rear upper control arms are non-replaceable as they are captive to the arms.
toyota32
Jul 6, 2015 05:42 PM
Vargntucson
Jul 4, 2015 12:15 PM
CJ94yota
Jul 3, 2015 10:14 PM
Niameyrider
Jun 25, 2015 05:50 AM
