Antifreeze leak from pipe below sending unit
Old 02-01-2012, 05:53 PM
red toyota's Avatar
My 89 p/u with a 22RE engine, has an antifreeze drip where the heater hose pipe is bolted below the sending unit, located under the intake manifold. I can see it by opening the panel above the passenger tire & looking up. I want to change the O-ring first. The tube goes around the back of the block to a rubber hose. Can it be taken lose behind the block to lower the pipe and change the o-ring? What's the best way to do this? Hopefully that would stop the leak. Or can the whole tube be taken out? The dealer says they remove everything out of the way - very expensive.
Old 02-01-2012, 05:55 PM
toyota4x4907's Avatar
22re or 3vze?
Old 02-01-2012, 06:03 PM
red toyota's Avatar
The engine is a 22RE.
Old 04-11-2012, 03:37 AM
lululalalu's Avatar
red,
I need to replace the same o-ring. What did you wind up doing? I don’t want to remove the intake to get to it.
Thx,
Doug4320
03-24-2018 10:11 PM
gary4runner
09-24-2015 12:53 AM
skoti89
09-11-2015 07:46 AM
Odin
07-15-2015 09:28 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: Antifreeze leak from pipe below sending unit
