Bilstein 5125 shocks w/ 99 coils??? Doable?
Old Sep 26, 2009 | 04:16 PM
ToyotaGuy02's Avatar
So I researched all the ways to lift the front of my 2002 Runner. I'm looking to get 2.5" to match the OME coils in the rear.
I put in some daystar spacers up front that I 'm not happy with. Turns out that my front struts need replacing also.
I recently found some 'tall' '99 coils from a member here and I want to run them with the Bilstein 5125 shocks to get my desired lift. Now I'm hearing everyone say that they drive like ass on a 4runner on stock coils? Is there a difference in the 5100 and 5125?
Anyone here running a similar setup that can chime in??
Old Sep 26, 2009 | 04:23 PM
Kerby J's Avatar
try trekmaster trail masters i have them and love them
Old Sep 26, 2009 | 06:27 PM
Hey,
are those lift shocks with adjustable height? I'm also trying to get a lift out of the front end to match the 2.5" rear coils.
Cheers!
Old Nov 10, 2009 | 10:58 AM
jrock's Avatar
N86C vs 5125
looking for info on similiar topic w/o starting new thread.
Which is best to match w/OME 890 for rear of my 98 4runner.
bilstein 5125 or N86C?
not running heavy loads in rear etc.
thx
Old Nov 15, 2009 | 01:32 PM
I have the 906 OME springs in the rear of my truck with the OME shocks and it rides great. I would go all OME if I were you unless you just want the Billies for extended travel.
Old Dec 3, 2009 | 12:03 PM
jrock's Avatar
5125 with OME890?
any feedback on the 5125s? bilstien coupled with OME coils good idea?
Old Dec 5, 2009 | 01:16 AM
SharpStick's Avatar
I'm running 890s in back of a '96 with the yellow Land Cruiser Bilstein (B461478) and a TRD Tundra blue/yellow swap in front on the adjustable Billies 5100 (BE5-6929-HO) and an All-Pro 1-inch spacer. It's pretty level, and I trail the living crap out of this thing. I can haul a bit of weight in back and there's no problem. The back axle articulates great, and the fronts stuff like champs.
You can read about the whole install and all the thoughts that went into it on off-road.com:
http://www.off-road.com/trucks4x4/au...l.jsp?id=45041
STICK to the story
Old Dec 5, 2009 | 03:54 AM
Deceptiwave's Avatar
Interested in the 5125 answer myself. Would you use the Landcruiser shock or the 4runner shock with the 890s?
Old Dec 5, 2009 | 04:35 AM
BajaRunner's Avatar
Talking with Steve at Sonoransteel.com, I believe that the BEST match up is that of a Tundra 4x4 coil and custom valved 5125 Bilstein shock. I'm leaning that way for sure.
As for the rear, I couldn't be happier with my Fj80 Landcruiser coils and OME landcruiser shocks
Old Dec 5, 2009 | 05:22 AM
what shocks did you use for the rear?
Old Dec 5, 2009 | 07:37 AM
BajaRunner's Avatar
My sigline link details my suspension, but Landcruiser OME N71E shocks.
Old Dec 5, 2009 | 09:42 AM
JWaldz's Avatar
havent gotten it installed yet, but working on it
Old Dec 5, 2009 | 12:42 PM
crolison's Avatar
i'm using 891's and 5125's out back and, using the heavier valving and i carry a lot of junk and it works awesome.
Old Dec 5, 2009 | 04:14 PM
Jwaldz, what are the brass hangers on the top of your rear shocks? Is that sturdy for the rear end? And where did you get your gear?
Old Dec 5, 2009 | 04:22 PM
BajaRunner's Avatar
Doubt those are actually brass Probably hardened steel. They are adapters to make the eye/eye bilstein shocks work with the rear of our 4runners which have a stud/eye configuration.
98srx6's Avatar
It is an adapter for the top shock mount type used on 3rd gen 4runners. You can see it better on toytec's site. I assume this same shock can be used on a tacoma if you remove the adapter.
Link to ToyTec Site
Old Dec 5, 2009 | 08:23 PM
JWaldz's Avatar
yea, it's not brass.. I got everything on toytec.com they have great stuff. I have seen a lot of mixed reviews on the ome vs bilstein shocks but I wanted to give the bilsteins a shot so I got the extended 5125's and the adjustable 5100's. I can't wait to test out the travel of these things.
Old Dec 5, 2009 | 08:26 PM
How about the Nitro charger LC shocks (OME N71E replacement) and the 890 coils for the rear? Maybe too stiff?
choppe777
May 16, 2016 08:00 AM
1965chevy
Sep 20, 2015 07:33 PM
mojo4x420
Sep 16, 2015 08:07 AM
Dparr2ndgen
Sep 8, 2015 01:06 PM
