My plan of attack
Old Jun 27, 2007 | 09:37 PM
wormhole's Avatar
My plan of attack
Okay, so I'm complying ideas for what I want to do to my 4runner. I plan on doing this in stages and as money allows. Here's what I'm thinking.
Stage 1
Sliders (already installed)
mild lift sonoran steel system 3 (ordered)
99 headlight/center console swap
rear diff breather
Stage 2
ss 7 lift or toytec or something else
tjm 17 or arb front bumper / rear bumper if I can find one
aux. lights (roof console swap to house the switches)
tires
Stage 3
rear locker
anything else I can think of (sas , crawl box)
Granted this isn't an all inclusive list and things will change or go in order. As will my demands for my 4runner. This is also an updated of my mod or not thread.
Old Jun 28, 2007 | 05:13 AM
DirtyDeeds/DirtCheap's Avatar
Stage 1
rear diff breather
Stage 2
tires
Stage 3
rear locker
Granted this isn't an all inclusive list and things will change. As will my demands for my 4runner. This is also an updated of my mod or not thread
If you're goal is greater offroad capability I would suggest:
Stage 1
rear locker or LSD(dramatic improvement over an open diff)
diff breather
Stage 2
SS#7(do a lift right the first time and forget about it)
bodylift(for extra room for larger tires)
tires
Stage 3
bumpers,lights and other cosmetic mods
Old Jun 28, 2007 | 05:33 AM
wormhole's Avatar
Stage 1
diff breather
Stage 2
tires
Stage 3
The reasoning behind the ss 3 lift is because my shocks are shot and they need to be replaced and I don't have the $$ at the time to do the ss 7 lift let alone a locker. You do make some good points though.
Updated my orignal post.
Old Jun 28, 2007 | 07:35 AM
I'm in the same situation in terms of $$.After getting the tires and the Truetrac,everything else is on hold.
Old Jun 30, 2007 | 09:01 PM
wormhole's Avatar
Thanks for all of the replys guys. Now I'm probable going to be beating a dead horse here and I've searched just need to do it a little more.
Any how when it comes time for a rear locker ($$ first). Which would be the easier route to go. Retro fit the 3rd memeber, get an axle that is already setup with the locker or get an arb/lockright locker.
From what I've read up to this point doing the retro fit seems to be pretty extensive and time consuming, so would it be easier to swap axles or should I just throw both those ideas out the window and just get a arb locker? Just trying to plan.
Old Jun 30, 2007 | 09:36 PM
91TPU's Avatar
you dont need to change out the whole axle, just pull the third member and replace it with a new one...or you could pull yours and install the locker...easiest way tho is to go to marlin, or trailgear and order a fully assembled third member.
Old Jul 10, 2007 | 09:20 PM
wormhole's Avatar
Checked up on an axle with a locker:
I contact tap auto recycling in California. They quoted 900 for the axle and another 150 for the harness and switch. Does that sound about right?
It seems to me like that would be less time consuming and cheaper than buying a third member and modifing the axle.
Granted this probable won't come about for a while, until money allows.
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
mreagen
Oct 5, 2015 04:27 PM
1985 4Runner
Sep 30, 2015 10:17 AM
