Is this the dreaded axle seal leak?
Old Jun 27, 2007 | 02:24 PM
GhostriderTx's Avatar
Is this the dreaded axle seal leak? Updated with pics
GRRRRRR Pulled the rear drum at 70k to look at the brakes. No need to reshoe for a while and everything looked fine. However I felt behind the backing plate and got a film of oil on the fingers. Nothing is on the shoes so if it is the seal its early. Is oil behind the backing plate the first symptom of a blown axle seal?
Edit - Looked today in better light, The backing plate is not oily just dirty. Brake cylinder looks fine. The plate with the lug bolts is oily. Nothing on the shoes. A few pics
The shoes look OK but you can see stuff behind the plate and two pics with a better look at the stuff. Is this what the blown seal should look like?
The starnge thing is that it doesn't really smell like differential oil..
Old Jun 27, 2007 | 02:27 PM
eric-the-red's Avatar
If is smells like gear oil then yes, otherwise it could be a slight brake fluid leak
Old Jun 28, 2007 | 05:56 AM
mjwalfredo's Avatar
My guess is it's just brake fluid if it's only on the backing plate.
Old Jun 28, 2007 | 06:05 AM
NPE701's Avatar
Leaking seals would give you wet shoes and the drum and pretty much everything else below the axle level.
Old Jun 28, 2007 | 08:40 AM
It does not smell like differential so maybe brake fluid even though it is black. It may be black from mixing with brake dust. Any thoughts on what to replace? I plan to get out and clean everting up and hopefully see where it is coming from - if it ever stops raining
Old Jun 28, 2007 | 09:51 AM
sharrack's Avatar
A common problem and I encountered the same thing on my 99 runner a while back.
It's a messy full day job and it all starts with shooting brake clean on the whole area and cleaning the backing plates and pads.
Both of mine were leaking and looked bent and deformed.
You'll need a seal puller and you'll need a seal installer to do it right.
Using a hammer and anythiing other than a perfect round device results in
a bent seal.
Seals can blow out from pressure built up in the rear end.
Check that your vent isn't plugged up.
Less likely to be the wheel cylinder but just look at it.
If there's no wetness on the cylinder .........it's the axle seals.
Kenny S>
Old Sep 30, 2010 | 11:41 AM
Citykid's Avatar
Could the axel leak be mistaken for a slave cylinder leak?
Old Sep 30, 2010 | 09:18 PM
raydouble's Avatar
They would be on opposite ends of the vehicle....so.....hopefully not.
Old Sep 30, 2010 | 11:35 PM
Citykid's Avatar
There's no brake cylinder in the rear?
Old Oct 1, 2010 | 06:18 AM
mjwalfredo's Avatar
Yeah, there is a cylinder in the rear... However, I hope Ghostrider has gotten the issue resolved since June 2007
Old Oct 1, 2010 | 01:16 PM
JWaldz's Avatar
Old Oct 1, 2010 | 05:05 PM
raydouble's Avatar
I've just only ever heard them called wheel cylinders....slave cylinders are clutch components.
Colington
Mar 8, 2020 09:51 AM
polo451
13
Nov 20, 2016 07:49 PM
yourrealdad
Jul 21, 2015 11:13 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
