The 5runner: badges and lights
Old Jun 14, 2007 | 11:48 PM
the_gunslinger's Avatar
this weekend I'm planning on removing my badges (with dental floss, a bondo scraper, some goop-off, and maybe a bit of lacquer thinner if the glue poses problematic) and I was wondering if y'all have any advice that'll make this turn out any better?
also, it seems my corner lights (driving lights?) aren't working. I'll dig in and replace the bulbs, but i don't think the corner lights worked on my '91 p/u either. I might take the time to hook up some 'strobes' (corner, blinker, and headlights) as well as installing a PA system and I'm just searching for a little advise. thanks in advance. (the ions will come in time)
If I can get a hold of a digital video camera, i'll be making a 'top gear' style documentary of the '97 toyota 4runner mine is based on.
Old Jun 14, 2007 | 11:58 PM
Elton's Avatar
use fishing line for the badges and a blow dryer or a heat gun to soften the glue and the corner lights take a 194 type bulb or you can put a 912/921 bulb in there brighter
Old Jun 15, 2007 | 12:18 AM
cool, thanks. yea, i planned on using a hair dryer....
Old Jun 15, 2007 | 08:03 AM
Bandit Runner's Avatar
I removed my badges with just a plastic putty knife. Didn't scratch the paint or anything, just kept wiggling it back and forth under the badge. Then I used WD-40 to eat through the foam tape that was left, but that still left the adhesive. So I used GooGone for that. Then wash and wax. Worked out real well.
Old Jun 15, 2007 | 08:05 AM
tampabayota's Avatar
do you have any plany for the badges when you get them off???
Old Jun 15, 2007 | 08:32 AM
neliconcept's Avatar
is your number 4 key broken, why are you calling it a 5runner
Old Jun 15, 2007 | 09:22 AM
Rock Slide's Avatar
Yeah, removing the badges is easy. I used fishing line to remove each emblem and goo gone to remove the glue.
Be careful removing the toyota logo right above your vehicle's tag, b/c it's not only held on by glue, but also has 4 tabs that snap into the tailgate itself. (hope that makes sense)
Old Jun 15, 2007 | 09:37 AM
by tag, you mean license plates?
it's a 5runner. i shouldn't have to explain why...
Old Jun 15, 2007 | 09:42 AM
Rock Slide's Avatar
Correct. The front emblem on the grille just snaps in...no glue.
The rear emblem above the license plate not only uses glue, but snaps into the body of the hatch as well.
Old Jun 15, 2007 | 09:44 AM
harpen123's Avatar
goo gone and hot water
Old Jun 15, 2007 | 09:58 AM
damn, i wanted to get rid of that (4runner) emblem as well. how many holes? i might be able to fill 'em with fiberglass, and repaint...but that'll be another day
when i make a grille (maybe a black or stainless mesh) i want to put the little toyota emblem in the lower left corner. i have no plans for the SR5 badge, yet...
Old Jun 15, 2007 | 10:12 AM
Rock Slide's Avatar
okay, let me re-phrase what I said earlier. The emblem that's the "Toyota logo" right below the rear window glass, close to the wiper arm, has 4 small holes holding it in.
The emblem that spells out "4Runner" right above the license plate (and below the one I mentioned above), I'm not sure about. My '02 did not come with that particular emblem.
Old Jun 15, 2007 | 10:16 AM
Avsfreak1234's Avatar
I took my badges off with a heat gun and floss. I like the look a lot better now.
Old Jun 15, 2007 | 10:18 AM
oh, alright, thanks. yea, i figured that one had clips...it doesn't wiggle. i should be able to remove the 4runner badge (and glue it to my neighbors RAV4 )
Old Jun 15, 2007 | 11:53 AM
Rock Slide's Avatar
Well, I just found out, that emblem that says "4Runner" (the one you were talking about) right above the license plate, is held in with tabs too! So if you remove it, you'll have 4 holes left to fill just like the toyota logo above it.
Check out the 3rd picture from the top in this link: Emblems
Old Jun 15, 2007 | 12:01 PM
thanks, i've got some fishing line (12 lb ) and some goo gone... time to start the destruction. i'm gonna try to get the dealership sticker off as well...wish me luck.
Old Jun 15, 2007 | 12:47 PM
rearviewmirror's Avatar
That reminds me, does anyone have the link to the Black Pearl 4Runner emblems?
Old Jun 15, 2007 | 01:09 PM
Rock Slide's Avatar
Meaning, how to turn your own emblems into the black pearls or where to buy them?
If you want to know how to make the "poor man" black pearls, check the link I posted above...that's it.
If you're talking about buying them, I picked mine up from a friend at my local toy dealer.
Old Jun 15, 2007 | 01:11 PM
cackalak han's Avatar
Park it out in the sun (it's about 100 degrees where I'm at, so I'm sure you're getting your share of the sun in Texas, too. Heat gun/blow dryer works, too, but just parking it is easier.
Regarding the rear license plate holder, I'm wondering if the 99+ with no holes will fit 96-98's? When I had my 98, I took the emblems off, and was going to keep them off, but the 4 holes looked hideous. So I painted the ugly gold emblems to a graphite color and put them back on.
Old Jun 15, 2007 | 01:28 PM
91muddog's Avatar
i want to know this 5runner nonsense.
what, is it a 5WHEEL DRIVE now?
