sway bar bushing replacement?
Old Jun 24, 2007 | 08:31 PM
wormhole's Avatar
How hard is it to replace the front sway bar bushings in a 96 4runner 4x4?
Old Jun 24, 2007 | 09:09 PM
Godzilla's Avatar
well to answer your question completely..it is not hard. however I am unaware of your abilities with tools.
Old Jun 25, 2007 | 12:42 PM
JC_ez's Avatar
In my opinion it is very easy. You just need basic tools. Crawl under the truck and locate the front sway bar connection to the frame. The sway bar goes across just behind the steering rack. I believe you will need a 12mm socket. There are 2 bolts holding the sway bar to the frame via a rubber D bushing. One of the bolts is welded to the bracket. Just undo bolts, take down bracket, remove and replace bushing, then reinstall. Torque specifications are 14 lb*ft for the bolts holding the sway bar to frame and 14 lb*ft for sway bar connection to the endlinks.
A hint is not to remove both sides at the same time because nothing will hold the sway bar up and it will fall down. Remove one side at a time. The opposite side may need to be loosened to ease installation. Make sure the sway bar is centered before tightening everything down.
Old Jun 25, 2007 | 01:30 PM
eric-the-red's Avatar
All this is assuming the bolts aren't completely rusty and snap off, it's a good idea to spray them with penetrating oil the day before.
Old Jun 25, 2007 | 02:55 PM
mjwalfredo's Avatar
I can attest to this. Make sure you do it!
Old Jun 25, 2007 | 02:59 PM
MillerPKA's Avatar
or as i recommended in another thread, borrow a shop's air tools for a second and loosen, then manually tighten, go back to where you've been working on it and have at it
Old Jun 25, 2007 | 04:51 PM
Nice writeup and thanks for the specs, cuz I'm getting ready to do this
Old Jun 25, 2007 | 06:17 PM
cackalak han's Avatar
It was very easy to do for me. You just need basic tools. I made sure to spray some PB Blaster the night before. Rest was cake.
The hardest part will be getting bushings that will fit. If you get them from the Toyota dealership, they'll fit no problem. If you're getting aftermarket bushings...well, I ended up throwing mine away, because they did not fit at all.
Old Jun 25, 2007 | 06:28 PM
jminz's Avatar
What difference do the bushings make in the ride quality? Or a better question would be, what are some symptoms of bad bushings?
Old Jun 25, 2007 | 08:06 PM
wormhole's Avatar
Thanks.
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
andrewtexas123
Jul 14, 2015 04:29 AM
ptb12
Jul 5, 2015 01:49 PM
Vargntucson
Jul 4, 2015 12:15 PM
