Advice on rear drums
Old Jun 25, 2007 | 05:06 PM
GhostriderTx's Avatar
I found lots of good advice on the front brakes but little on the rear. I have a 2001 SR5 4WD. Is there any issue with just turning the drums when I do the rear shoes or should i consider new drums. I am going with Brembo rotors on the front and would probably use them on the rear unless a cheaper Autozone drum would work.
Old Jun 25, 2007 | 05:10 PM
Knuckles's Avatar
Get them Turned if their still within specs.
I wouldn't Purchase after market shoes, Go With Toyota Brake Shoes, I Got Raybestos and realized they didn't fit right even after I Adjusted the Adjuster Wheel. So My Mechanic Friend took a look and told me they were the problem. So he got me a set of Toyota Shoes and we put them on and everything went fine after that. So save yourself the trouble that I had. Be Sure to Inspect your wheel cylinders and change them if needed.
Old Jun 25, 2007 | 08:09 PM
eric-the-red's Avatar
Do the rears need done, on my 01 there's still about 50% left on the shoes
Old Jun 26, 2007 | 09:58 AM
Mason Dixon's Avatar
only if gear oil has seeped into them
i had my drums turned this year and that helped out with a lil shimmy i had back there
icentropy
Sep 16, 2020 02:47 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
Vargntucson
Jul 4, 2015 12:15 PM
