Transmission Drain Plug
Old Jan 17, 2005 | 07:28 PM
TrevorR's Avatar
I just got under my 1993 4Runner with the 3.0L (auto) to change the oil...and noticed two plugs that where close to each other....one was the transmission drain and i cant figure out what the second plug is for...maybe just a second drain?..correct me if im wrong but the transfercase drain and fill plugs face the rear of the vehicle....and i believe in this application the drain on the transfercase had an allen head in it.
Old Jan 18, 2005 | 04:53 AM
MTL_4runner's Avatar
Got a pic you can post on this?
Are they both on the tranny pan?
Old Jan 18, 2005 | 06:11 AM
mt_goat's Avatar
Here is some great info on changing your ATF: http://www.gadgetonline.com/TransFlush.htm
You are correct the transfer case drain and fill plugs face the rear of the vehicle. I have seen that 2nd tranny oil pan too, but I have never drained it or removed it. On my BMW there is a 2nd small tranny oil pan too that I have dropped and cleaned out. I think it is called a sump pan? There was no pickup tube in it, I guess it is just a little reservoir that collects sludge. On our Toyotas it looks like you would have to remove the cross member to drop that little pan though.
Old Jan 18, 2005 | 07:32 AM
The second plug is also for the trans and should be drained when the trans is serviced.
Old Jan 18, 2005 | 01:26 PM
TrevorR's Avatar
Thanks for all the responses....yeah...i asked around and that seems to be the general consensus.....apparently it is just a separate sump.
Old Mar 17, 2005 | 07:40 PM
Towsonboy's Avatar
I have a 92 3vz-e and I just drained my sump because I thought it was the transfer case drain plug(which I'm not sure exists) Anyways, does the sump need to be refilled or does it refill from the transmission fluid pan? If not..how is it refilled. I didn't see a refill hole on the sump pan; but maybe I missed it.
Old Mar 18, 2005 | 01:22 AM
leebee's Avatar
a couple of the guys on here have the factory service manual, do a quick search to find out who and pm them. they should be able to send you a copy, it has everything youll need.
lee
Old Mar 18, 2005 | 05:09 AM
mt_goat's Avatar
I assume you have an auto tranny right? If so, it is part of the transmission so you will need to add some ATF to replace it through the dip stick tube for the tranny fluid. The level needs to be checked with the transmission hot and the engine running just after shifting through all the selections with the shifter.
The transfer case has drain and fill plugs on the back of the t-case (facing the rear of the truck). Make sure you take the fill plug out before the drain plug just in case you can't get the fill plug out you won't be stuck with no ATF in your transfer case. You fill it until the ATF runs out of the fill plug.
Old Mar 18, 2005 | 01:07 PM
Towsonboy's Avatar
That was fast! Thanks for your quick reply and instructions, it is much appreciated.
smthwsn357
May 1, 2024 07:28 AM
kcaudill
Jul 20, 2015 12:06 PM
daddio
Jul 18, 2015 10:20 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
