Door with Yakima Racks LEAKS
Old Jan 14, 2005 | 09:58 AM
FORANA's Avatar
Hey gang. i'm sure some of you have yakima rack on your 4runners. Does anyone have trouble with leaking where the racks are anchored? The clip goes over the rubber gasket lining the door and this allows water to seep in through the door jamb. Anyone have this problem? Anyone have any solutions? Let me know!! Thanks
Old Jan 14, 2005 | 10:06 AM
Yoter's Avatar
Guest
post a pic, i might be able to help.
Old Jan 14, 2005 | 11:00 AM
User 051420's Avatar
Are you talking about the Q-Towers? My first plan of action would be to make sure they're EXACTLY where Yakima specifies them to be, it's critical. After that, I'd call Yakima.
Old Jan 14, 2005 | 11:21 AM
dlbrunner's Avatar
I had those racks before, I am not a fan. When the clip wraps around the door seal it deforms it there is no way around it, some seal better than others. I replaced those with control tower? it fits in the stock rail of the exploder with a little adapter. My runner does not have those yet, new yakima tracks should be here next week. I kept all the hardware from the exploder, so I should be good to go. I'll maybe post a few pictures when I am done
Old Jan 14, 2005 | 12:38 PM
li_runner's Avatar
You need to reposition the q-towers to the exact spot where they are supposed to be as per yakima as said before. Any deviation will lead to what you have now a bad door gasket seal.
Old Jan 14, 2005 | 02:25 PM
Bluedog's Avatar
Do you have a factory roof rack you can tie into? If not, your only option is to re mount the rack (if it's in the wrong spot). If you don't use the rack on a regular basis, take it off and give the door seals a chance to recover. Yes, I know it's a pain.
Do you have the Q towers?
Old Jan 15, 2005 | 06:55 PM
CMD93's Avatar
I always run that Yakima setup with Q-towers and I have never had a problem.
Old Jan 16, 2005 | 06:33 AM
CappyKD's Avatar
I went with the Yakima tracks that can be laid down on any roof. I had the sports rack install the tracks onto my rear roof. = No door issues. Well worth it.
Old Jan 16, 2005 | 06:41 AM
outdoorfever's Avatar
mine leak on driver side but its because i ripped mine out. before that it was perfect.
Old Jan 16, 2005 | 06:59 AM
ekim121's Avatar
You put them over your door seals? When I installed my rack with the Q-towers on my parent's mercury sable I just made little slits in the weather stripping and ran the clips under the stripping. That was about 3 years ago and the 'rents haven't had leaking problems yet. Also, as others said there should be a control tower application for the 4runner that will allow you to affix it to the roof. I know both yakima and rei's websites have the fit guide that will show you all of your options.
Old Jan 16, 2005 | 07:28 AM
cstem's Avatar
I have had Yakima racks on three of my vehicles- that latest being my 91 Toy pickup (I run a shell on back and carry the bikes on top with camping gear in the shell) and have had no trouble. First make sure you have the proper clips. The part number will be on the clip (one or two digit numeral) and verify this on Yak website www.yakima.com If this is correct, make sure you have even pull on each side. If one pulls tighter it can cause abnoraml seal distortion. If you still have trouble, call Yakima. Thier number is on the web and they are pretty helpful. ALso if you have y clips and y towers (older version of the Q tower) they can cross ref the part numbers for you. Good luck.
Old Jan 20, 2005 | 12:35 PM
dlbrunner's Avatar
I just installed the yakima 42" tracks last night, and put my railrider 1 towers on. I'll try to post a pic soon. Scary drilling 10 holes in the roof! but no clips,and I like the adjustability of the tracks. if the cross bars are too far apart you can easily steal skis or snowboards out of a LOCKED ski holder.
I should have put on the 54" tracks, but the yahoo at REI barely understood what I was asking for in the first place, so I measured and thought the 42s were closest to the factory size.
Running boards come off too, 4runner is looking less like a mall car and more like the vehicle it was intended to be
jasonty
41
Dec 23, 2018 01:00 PM
theking11863
Mar 19, 2016 09:36 PM
Athansinis
Jul 27, 2015 08:38 AM
itzmywife's
Jul 25, 2015 04:55 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
