2000 4Runner 4WD light won't turn on....
Old Dec 31, 2010 | 11:22 AM
WestEnd's Avatar
Got a 2000 4 Runner. Had the tranny replaced last September, and have never tried to engage the 4WD since that time.
When I shift the 4WD lever to 4-Hi, the green light on the dash no longer comes on.
I briefly tried to check things out the other day by raising all four corners of the rig and putting it in 4WD. The 4WD engages fine, but the green light still doesn't come on.
Any ideas?
Old Dec 31, 2010 | 11:47 AM
justin_4runner's Avatar
bulb burned out.
Old Dec 31, 2010 | 12:29 PM
WestEnd's Avatar
verified bulb is OK. Any other ideas?? Also checked wiring harness continuity...
I did notice that when they replaced the transmission, they didn't hook up the hose going from the base of the transfer case shifter to the transmission... I'm guessing it's some sort of vent hose????
Anybody else seen that hose before??
Old Dec 31, 2010 | 02:31 PM
BigBallsMcFalls's Avatar
4wd is vacuum activated (some bits are anyway) I am unsure of exactly
which...but that may be a vacuum line required for proper 4wd operation
Old Dec 31, 2010 | 02:42 PM
TheDurk's Avatar
If you do have 4WD, but no light, your problem is either the bulb, the sender switch on the front diff, or the 4WD computer. Odds on bet is the sender switch. Pull it and check for continuity when operated.
On the hose, I think you are talking about a breather that vents up by the shift levers.
Old Dec 31, 2010 | 03:11 PM
WestEnd's Avatar
OK, I just got the "vent" hose back in place, and took it for a drive, and lo and behold... the 4X4 light works...
Could this be some vacuum source, as Big Balls McFalls suggested? I will take a pic of the hose this weekend so you can see the shape of the hose, as it is a preformed hose.
gillesdetrail
Nov 19, 2019 12:56 PM
Aleeex_u
Jun 5, 2016 06:52 PM
aciorba23
Jun 29, 2015 04:18 PM
ACZR
Jun 23, 2015 07:55 PM
Schif
Jun 20, 2015 08:39 PM
