Clunking on Rolling Start, Deceleration to Stop
Old Feb 19, 2011 | 08:25 AM
VolVette's Avatar
My AT, SR5 '98 4Runner clunks after releasing the brake from stop to a rolling start and also when decelerating to stop. It feels like it could be transmission or differential. What does your experience suggest?
Appreciate the help.
SES
Old Feb 19, 2011 | 08:42 AM
rezrunner's Avatar
Sounds like it could be your U-joints. Or lets hope so since it would be an easier fix. You can manually rotate the driveshaft and see how much play there is at the U-joints. You may even reproduce the sound.
Old Feb 19, 2011 | 09:22 AM
brian24's Avatar
I have a very minor version of these symptoms as well.
97 4Runner @ 195,0000
Old Feb 19, 2011 | 10:42 AM
BajaRunner's Avatar
I just fixed this problem by greasing the crap out of my u joints and slip yolk.
I had jacked up the rear to play around with the driveshaft but couldn't see or hear any play, so I just did all of them until all the old grease came out (probably 10 pumps per u-joint fitting, and 30 pumps for the slip yolk).
It should be mentioned you should not over grease the slip yolk. I think mine needed a ton because it had never been greased in 14 years.
Old Feb 22, 2011 | 10:10 AM
SkidPalace's Avatar
Grease the hell out of your slip yoke. Pump it until the grease that comes out is the same color as new grease. Drive it for a while and then you may have to do it again, possibly a third time. The ideas is that you need to flush/purge out the old rotten grease that may have been in there untouched since new.
I have read, though, that perhaps sagging rear springs can contribute to the problem.
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Jul 11, 2015 07:21 AM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
