Need some help diagnosing a diff / oil leak
Old Jan 23, 2011 | 01:16 PM
BMWToyotaMan's Avatar
Just recently pulled my skid plate off to do an oil change, noticed i had a lot of residue from some kind of lubricant on the top side of the skid plate. It just looked like the greese from the cv joints since both just blew out. However, after doing an oil change and letting the truck sit over night I saw a decent sized puddle under the 4wd half shaft on the passengers side. I thought it was oil so I checked my valve cover- it definitely could use a replacement but didnt appear to be leaking much if anything. I smelled the fluid and it had a definite diff fluid smell to it. So can diff fluid leak out of this area or is it just leaking down this way from higher up on the engine?
Old Jan 23, 2011 | 08:58 PM
anyone have any advice?
Old Jan 23, 2011 | 09:00 PM
camo31_10.50's Avatar
is it really thick?
like a heavy weight gear oil, or is it thin like motor oil
Old Jan 23, 2011 | 09:06 PM
Lextech's Avatar
Looks like it's coming from the axle seal... Pretty common
Old Jan 23, 2011 | 10:26 PM
seems like motor oil in terms of thickness.
Old Jan 23, 2011 | 10:27 PM
if you think it's got the consistency of motor oil, then start looking above that spot for some oil leaking from the motor.
Old Jan 23, 2011 | 10:36 PM
I couldnt see it leaking from anywhere up there. the one spot it could have leaked from would have put it in a different spot towards the front of the truck, not over the front axle.
It seemed like the consistancy of normal oil but just smelled like diff oil, thats whats throwing me off.
Old Jan 23, 2011 | 10:42 PM
it could be diff oil then lmao wouldn't surprise me
Lextech's Avatar
The power steering pump and high pressure feed hose is on the passenger side... Both power steering fluid and gear oil have quite the distinguished smells...
Old Jan 24, 2011 | 05:30 AM
BajaRunner's Avatar
If it smells like diff oil, then it probably is. Motor oil, when I smell it from my finger doesn't have much scent. Diff oil does. Sounds like an axle seal. Guess is that when you changed your CV boots, you either damaged the seal, or it was already ready to go when you pulled the CV's out.
Old Jan 24, 2011 | 06:51 AM
I haven't replaced the cv's yet but will do so now!.
Jeff
Old Jan 24, 2011 | 07:26 AM
Wheres the best place to get the oem half shafts? My dealer charges too much, any recommended websites? Not looking for off brand here.
Thanks for the help everyone.
Old Jan 24, 2011 | 07:38 AM
E30RUNNER's Avatar
TRDparts4u
Old Jan 24, 2011 | 08:25 AM
cant seem to find them on there, they dont have much for oem replacement parts. Hoping to find a site that will also sell the diff seal.
Old Jan 24, 2011 | 09:37 AM
obscurotron's Avatar
TRDParts4.com won't cut it. You need to go to their OEM replacement part site (same folks, different URL) at http://www.toyotapartsales.com.
Old Jan 24, 2011 | 10:53 AM
Just ordered some rebuilt cv's from cvunlimited.com 49 bucks a piece.
Old Jan 24, 2011 | 11:01 AM
BajaRunner's Avatar
Its fairly easy to put new boots and grease on yourself. Its just messy.
Are the CV's OEM replacements or aftermarket?
Old Jan 24, 2011 | 11:04 AM
re-manufactured oem's
Old Jan 24, 2011 | 11:38 AM
cordrayj1's Avatar
nice ive been looking for somewhere to get toyota remans.
the1998sr5
15
Jul 14, 2020 08:35 PM
Eggslinger
Jun 8, 2019 03:32 PM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
