Rear coil spring removal/install
Old Feb 9, 2011 | 10:36 AM
jimig's Avatar
'02 Runner.
Installing PP springs this weekend and have searched for the past 2 days on a write up or some vague instructions on the process to remove the rear coils. I'm hoping someone can show me a link or pm me some instructions. Preferably someone that's not a search nazi. The only info. that i come across is for a 2nd gen. Would the same process be involved?
Old Feb 9, 2011 | 10:50 AM
waskillywabbit's Avatar
Look on the Toytec website.
:wabbit2:
Old Feb 9, 2011 | 10:56 AM
Elton's Avatar
the short and sweet version is unbolt the shocks the sway bar end links and if need be the trac bar
Old Feb 9, 2011 | 11:11 AM
jimig's Avatar
if i unbolt the sway bar end links, then does the sway bar fall out?
Old Feb 9, 2011 | 11:13 AM
jimig's Avatar
thanx wabbit. I have a feeling Im way overthinking this, arent I...
http://www.toyteclifts.com/images/st...stallation.pdf
Old Feb 9, 2011 | 11:20 AM
Yes.
Now do you see why the "search Nazis" tend to get just a tad pissed?
:wabbit2:
Old Feb 9, 2011 | 11:49 AM
dougiefreshmx's Avatar
If you follow those directions, it shouldnt take you more than an hour if that. And yes, dont over think it!
Old Feb 9, 2011 | 12:06 PM
jimig's Avatar
thanx guys. much obliged.
Old Feb 9, 2011 | 03:16 PM
KU_MechE's Avatar
Don't be afraid to replace the swaybar endlinks at the same time. They break due to rust/corrosion anyway, so might as well replace them now. Rockauto has some great prices on rear endlinks.
Old Feb 9, 2011 | 03:52 PM
4biker's Avatar
If the coils aren't falling out after unbolting the sway bar, step down on the brake drum and that will tell you how much play you have left. Mine fell out of the driver's side when I pushed down and the new one slipped right in. I think I have some pictures in my profile thread in my sig line (edit: I have exactly one picture - sorry). The sway bar is suspended by bushings, so it won't go anywhere. Springs are SUPER EASY compared to the shocks though. If you're doing the rear shocks, do a search first and I suggest an angle grinder or you'll be swearing a lot, with bloody knuckles.
88sasturbotoy
Jan 30, 2026 01:57 PM
terminator
Jul 27, 2015 07:13 PM
Massmayhem247
Jul 24, 2015 12:07 PM
Nickdigg
Jul 7, 2015 06:04 AM
Vargntucson
Jul 4, 2015 12:15 PM
