Somebody mentioned have a spin on filter for their trans
Old Jan 18, 2011 | 04:54 PM
BDTB's Avatar
I can't remember which post it was in, but can I see some pics? Also, who makes the best kit for this?
Old Jan 18, 2011 | 05:34 PM
J2F42C's Avatar
I have one, right after the fluid exists the transmission, which is not the ideal location ( it is supposed to be inline right before the cooled ATF goes back into the transmission), but I am a maverick at heart.
If you can wait till the end of the month, I'll post some pics of what is inside the filter (hopefully not much) after being on there for 23,000 miles. When I pulled my pan last year, I found no metal shavings in the pan so maybe the Magnefine is doing its job. For $16, why not? 3/8 barb BTW.
http://www.emergingent.com/subpage1Magnefine.htm
http://cgi.ebay.com/ebaymotors/Magne...Q5fAccessories
This one installed is for a power steering pump, but the idea is the same:
http://eturkov.blogspot.com/2008/10/...ine-power.html
Midget96's Avatar
Probably me. I used a B&M kit. You have to remove all the hard lines and use AN fittings to make it work. I used Summit Twist-Tie fittings, which work great and are super easy to install. Buy more 45°, 90° and straight fittings than you think you'll need; it's very easy to return stuff to Summit. An M14x-6AN adapter is what you need to hook into the actual trans input and output fittings. Figure <$300 total for all hoses, fittings, filter relocation kit and a good size B&M oil cooler.
There's an M10 threaded hole in the frame in the perfect spot to mount the filter adapter. Just behind the engine mount. Loctite the bolt, and/or use a lock washer.
Mine is plumbed in to filter right after the fluid exits the trans, and before it goes to the cooler. The B&M adapter block also had 4 1/2' NPT bungs, so it's very easy to add a temp sender here if you want to add a good temp gauge.
The Fram was temporary. I replaced it with a Purolator Pureone shortly after.
Old Jan 18, 2011 | 05:43 PM
J2F42C's Avatar
Midget's setup is the correct one to follow, also search under fellow poster Fogrunner for his setup.
Next time I'll try reading the OP's entire thread first before posting.....
Old Jan 18, 2011 | 08:25 PM
BDTB's Avatar
Awesome, thanks guys. Midget, your setup looks legit-like it was never 'not there', if that makes any sense. I'm under the assumption that plumbing this and a external trans cooler would simply entail installing the parts, filling the reservoir, and running the engine. Is this correct? Or is it a little more in depth than that?
Eggslinger
Jun 8, 2019 03:32 PM
crammit442
7
Nov 29, 2017 12:30 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
pyramid
Jul 30, 2015 10:05 AM
calderp
Jul 27, 2015 09:58 AM
