Key wont turn in door, and wont lock/unlock, plz help!
Old 02-15-2011, 12:06 PM
chris383's Avatar
Hi, strange lock issue here. its a 98 4runner, sr5.
Just noticed today that when i put my truck into drive, all the doors locked, except my drivers side. When I got where I was going and attempted to use the power lock, all doors locked except the drivers side. Locked it manually. when I tried to use the key in the door, the lock will not turn, left or right. The lock functions, as in I can move the post up and down manually, and it will lock and unlock in that way only. I am confused by why the key wont manually turn the lock. Any thoughts?
Thanks
Chris
Old 02-15-2011, 12:12 PM
xxxtreme22r's Avatar
I have a problem like this on my BMW, if your key is double sided try both sides by turning the key over.
Old 02-15-2011, 01:41 PM
spokane.yota.man's Avatar
its not frozen is it? I'm on mobile so I can't see you location. Also try graphite lube. It comes in a small spray can with hose. Last possibility is it broke or a clip came off. Take door panel off and inspect.
Old 02-15-2011, 06:08 PM
danimal92sport's Avatar
This is exactly what my 4Runner did when I had the factory SecuriKey alarm disconnected. It is a control module behind the drivers kick panel. My guess is that yours is malfunctioning, or is disconnected.
-Dan
jasonty
41
12-23-2018 01:00 PM
gary4runner
09-24-2015 12:53 AM
Esibnitsud
07-21-2015 08:51 AM
Hamonacracker
07-17-2015 08:33 AM
Odin
07-15-2015 09:28 PM
Quick Reply: Key wont turn in door, and wont lock/unlock, plz help!
