another o2 sensor question
Old Jan 17, 2011 | 09:09 AM
mk3supraman's Avatar
ok, i'm sorry to bother about another o2 sensor question. i have noticed that my fuel economy has started to dip down on my '97 4runner v6 sr5. my engine light finally came on and i didn't write down the code but the description stated that my o2 sensors had a slow response. so i am guessing that i need to replace my sensors. i'm just curious where i should purchase them, advanced autos has one for 89.99, napa has one for 111.99. any thoughts?
Old Jan 17, 2011 | 09:21 AM
snobdds's Avatar
Only replace with denso...there are many threads on here about that topic just search a bit.
sparkplugs.com has good prices on denso o2 sensors.
Old Jan 17, 2011 | 09:27 AM
DeathCougar's Avatar
Also, check your cats. Make sure the honeycomb isn't damaged or melted. If a cat is failing, it will give incorrect O2 readings. It would also indicate a problem in the engine, ie running too rich or too lean.
Old Jan 17, 2011 | 09:29 AM
TheDurk's Avatar
Go here to get the correct Denso part number and a decent price. For a better price, search for that part number on Amazon.com. Get the correct number first, Amazon's application info is sketchy at best. You can Google "Denso XXX-XXXX" using the number and check prices everywhere.
krimsonone
Sep 13, 2024 09:33 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
Gevo
Jul 29, 2015 11:15 AM
nonstop
Jul 24, 2015 06:29 PM
88yodabasket
Jul 13, 2015 01:32 PM
