Help install Toytech Coilovers
Old Dec 28, 2010 | 04:54 PM
jagermeister's Avatar
I have a 2000 taco ex cab and im lifting it three inches using toytech coilovers and all pro leafs. i already have all the stuff and am in the process of doing the front but ran into a problem. i can't get enough travel to bolt the bottom of the shock. I have the adjustable coilovers from them and i have unbolted the sway bar but still can't get enough travel. I was wondering if anyone had any tips of experience doing this anything would help thanks.
Old Dec 28, 2010 | 05:04 PM
scuba's Avatar
Take your bottle jack that comes with the truck. Place it upside down between the upper control arm and the inner fender well. The top of the jack should be on the upper ball joint bolt/ castle nut. Proceed to "lift" the jack up, thus pushing the suspension downward. That'll give you the room necessary.
Old Dec 28, 2010 | 06:46 PM
Gerdo's Avatar
Better yet. Loosen the bolt that mounts the upper control arm to the frame. This will allow it to fall without resistance. You can also loosen the lower control arm bolts. Don't worry about knocking things out of alignment. This will allow the bushings to release and won't have tension on them from being lifted.
Once you have the vehicle back on the ground, re-torque all bolts.
Remember that the suspension was originally torqued at stock ride height.
You also won't have this issue if/when you pop a CV.
yeah i acutely ended up unbolting the 4 bolts above the lower ball joint which made me get enough room to bolt everything in thank you though for the help.
Old Dec 29, 2010 | 06:20 AM
CodyX36's Avatar
When I did mine, I had my brother in law hold onto the washing machine while jumping up and down on the arm until I was able to get it down there to slide the bolt right in. Tough, and probably not the best way to go, but it worked.
Old Jan 4, 2011 | 07:24 AM
sl0annuggets's Avatar
Bottle Jack and rubber mallet. But also run a string to mark where you need to line the top plate to where the bottom mount should sit. Made a huge difference on the second side instead of beating the piss out of it trying to turn and force it in.
Old Jan 4, 2011 | 07:47 AM
waskillywabbit's Avatar
If you line the lower mount bolt perpendicular to a top stud (3 stud) then you'll be fine. Preassembled coilovers will be correct.
Loosening the 4 bolts on the underside of the lower A arm is what I always do as it's easy and safer than getting brained with a bottle jack slipping off a castle nut.
A 6' piece of 3" SCH 80 pipe as a cheater bar comes on handy too for prying things down easily with a 250 lb gorilla on the other end.
:wabbit2:
Old Jan 4, 2011 | 07:52 AM
peapicker's Avatar
take the sway bar off, ooops edit, sorry. You have already done that.
Old Jan 4, 2011 | 08:38 AM
okie81's Avatar
I know this is too logical, but adjusting the coilover all the way down will give you a few extra inches.
nvdesertrunner
May 11, 2020 08:18 PM
nick9455649
Aug 29, 2015 02:08 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
Steven.m.paulk
Aug 16, 2015 04:52 AM
Vargntucson
Jul 4, 2015 12:15 PM
