Removing Rear Differential Carrier
Old Feb 9, 2011 | 12:22 PM
YotaYeti's Avatar
1998 4Runner with locking differential
I am attempting to remove the rear differential carrier in order to rebuild (the howling has finally gotten the best of me)
First off it seems that the actuator is fried. When I push the button on the dash the light blinks???
I have the right axle off but cannot get the rest of the carrier out...something is stuck bad. Perhaps the shift fork?
I can hear the actuator motor turning when powered however nothing happens!! Any ideas on how to get the carrier out?
Thanks,
Mike
Old Feb 9, 2011 | 12:23 PM
scuba's Avatar
You need both of the axles out. Pull the actuator and move the shift fork over into the lock position with a screwdriver.
Old Feb 9, 2011 | 01:13 PM
BajaRunner's Avatar
Have you tried driving in tight circles for a few minutes with the diff lock on? I've read and heard about this working when the actuators are being sticky.
Old Feb 9, 2011 | 07:05 PM
cpizzle42's Avatar
really simple fix, you need to pull both axles out.
Old Feb 9, 2011 | 08:48 PM
dropzone's Avatar
Fossilized
you can also download the FSM from the link in my signature.
When pulling the rear third be sure to unhook the E Brake cables and your brake lines.
Some people will just pull the axles out far enough to get the carrier out and let the axles rest on the axle seals...if I do that I end up doing a rear axle seal later on...
Old Feb 10, 2011 | 05:48 AM
YotaYeti's Avatar
Thanks,
Mike
I have both axles completely out and the fork does not want to budge... any ideas on how to get the actuator out?
Old Aug 7, 2012 | 01:59 PM
Yota Yeti's Avatar
not to thread jack but I have the same issue with out the locker...just an open diff. both axles completly out. I can pry at it and the bottom will move (1/8") but not the top. It's is acting as if it is welded on. Any tips?
Old Aug 7, 2012 | 02:00 PM
Yota Yeti's Avatar
whoa... just checked the name out...kinda nutty but this is two different people.
Old Aug 7, 2012 | 09:07 PM
Yota Yeti's Avatar
I was able to remove mine using flat head screw drivers as wedges. Used 3 and a pry bar.
Ladythump
22
Nov 9, 2015 08:53 AM
jerusry
Oct 19, 2015 05:28 PM
icentropy
Jul 14, 2015 10:23 AM
AaronM
Jul 8, 2015 07:15 PM
ItsJustD
Jul 7, 2015 07:49 AM
