Cruise control disengages
Old Sep 20, 2006 | 01:29 PM
XPY's Avatar
XPY
My 99 4Runner seems to be experiencing some problems with the cruise control. I can set the cruise and it will engage, and the green cruise light comes on but if I hit any sort of bump in the road it will disengage, and I have to reset it just by pressing down on the cruise lever. Other than checking the wiring for good connections any other ideas? I just had the master clutch cylinder replaced if that might be relevant?
Old Sep 20, 2006 | 01:34 PM
Elton's Avatar
may want to check and see if theres not to much slack on the cable
Old Sep 20, 2006 | 02:33 PM
eric-the-red's Avatar
If it just satrted after replacing the clutch cylinder I would start by checking the switch that cancels the cruise on the clutch pedal. It's just like a brake light switch except it's on the clutch pedal. Maybe it got loose or needs adjusted.
Old Sep 20, 2006 | 02:45 PM
04 Rocko Taco's Avatar
Bingo
Old Sep 20, 2006 | 02:47 PM
mastacox's Avatar
^^^ X3 ^^^
Old Sep 20, 2006 | 03:08 PM
MTL_4runner's Avatar
Ditto......It could be the neutral clutch or brake light switches causing that situation.
Old Oct 18, 2006 | 08:46 AM
XPY's Avatar
XPY
Cruise control disengaging
Adjusted the cruise control disengage switch which is located just above the clutch pedal and gets depressed when the clutch is fully released. That seems to have resolved the problem.
Thanks
Old Oct 18, 2006 | 08:56 AM
gregbreakseverything's Avatar
I have to do the same thing, My cruise doesnt engage sometimes. After Kicking th clutch a few times, the cruise will engage. I just have a hard time getting stoked to work on the truck when its so cold out. And Its only going to get colder. I need a shop.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
kcaudill
Oct 10, 2015 02:39 PM
Shagool22
Sep 28, 2015 07:53 PM
toyotasaurus
Sep 24, 2015 03:30 PM
