Pics: 295's and 1" BL, + concern update
Old Sep 30, 2006 | 06:17 AM
KyleT's Avatar
Here are some quick pics of the 265's vs. 295's and 1" RB/4Crawler body lift. (update at bottom)
how she looked afew days after i got her.
lift and 265's lift not settled
295's and 1" BL
as you might have read, i had some concerns with the way it was riding and rattles, well i found most of the rattles i had was due to my roof rack coming a little loose and the rear panels not being popped in all of the way. I took it for a flex test and drove on some rough dirt roads and i think that helped settle everything, as it is feeling just as solid now as it did before. (that or its my imagination....). I do think that 1" is almost not enough for the 295's. i am going to have to trim a little near the pinch weld and I definately hit the rear bumper when i stuff, couldnt even get the rear stuffed all of the way... is the rear bumper adjustable>? i dont particularly want to cut it because i am planning a rear bumper build and need the resale from it....
what do yall think?
Old Sep 30, 2006 | 07:03 AM
BajaRunner's Avatar
For the rear, you should really cycle the suspension to see where the wheel will be hitting the bumper. Mine will hit the mud flaps, but, never the bumper, and I have 35's.
For the front, get an angle grinder and use a cut off wheel and cut it little by little, you can make it look very clean. I've never done it either, so Id want to wait for some people who have to chime in.
Old Sep 30, 2006 | 07:22 AM
KyleT's Avatar
yeah i cycled it, i had to take the muflaps off, and the limited flair things on the bumper front and rear, trimmed the front bumper plastic a little under where the limited flair goes, and had to take one of the bolts out on the lower edge of the front flairs near the pinch weld on each side. the only thing is the rear bumper, it hits it pretty good. I need to get the rear straightened out as it will be untill at least dec untill i can start on the rear bumper.
Old Sep 30, 2006 | 08:25 AM
4unner4life's Avatar
KyleT, That looks a lot better. Im Glad you got everything with the body lift straightenend out. Your front bumper looks like it's hanging down more than 1''.
Old Sep 30, 2006 | 08:38 AM
KyleT's Avatar
Yeah, the front bumper has always been a little crooked, i stood on it when i was messing with the motor and the mount shifted...
Old Sep 30, 2006 | 09:45 AM
how bad is the powerloss with 295's?
Old Sep 30, 2006 | 10:45 AM
KyleT's Avatar
not near as bad as everyone lead on to believe,i dont drive aggressivley anymore, so its good.
Old Sep 30, 2006 | 10:49 AM
fireteacher's Avatar
nice job. is that a new spare also?
Old Sep 30, 2006 | 10:58 AM
KyleT's Avatar
no, but i have a full size spare and lexus wheel combo... doesnt fit under.
Old Sep 30, 2006 | 04:34 PM
Albuquerque Jim's Avatar
It will fit if you remove the hitch.
BTW, the truck looks good.
Old Sep 30, 2006 | 04:51 PM
KyleT's Avatar
thanks,
now is there any way to get the rear bumper moved back a little? im going on a wheeling trip next weekend and dont want to mess it up and ruin my tire.
Old Sep 30, 2006 | 07:20 PM
Bighead's Avatar
Did you get the adjustable panhard rod from Steve when you bought the lift kit? The rear bumper rub issue sounds like what happens when you don't have the new rod or drop bracket.
Old Sep 30, 2006 | 08:46 PM
KyleT's Avatar
yeah i have the drop panhard bar.
it is rubbing for sure, the tire is just too big i guess....
Old Sep 30, 2006 | 08:53 PM
but it looks DAMN SEXY!!!
Old Sep 30, 2006 | 09:01 PM
KyleT's Avatar
oh yeah, update, i had to adjust the way that it was sittinng on the body mounts tonight.
I did the lift by myself and didnt get it all lined back up right. so i had my bro help me out, we loosened all of the mounts, and wiggled the body a little, and it kinda thudded and sat right where it needed to be, tightened everyhting down nice and snug and went for a drive. it drives as it did before the body lift. the resonance vibration is gone and so are all of the rattles minus the one that I cannot for the life of me find that has been there since i got it....
still need to figure out the rear bumper.
I guess i can try to find 2 side pieces that have been trashed and cut them up and sell my virgin undamaged ones....
i need like 1/2" or so i think, if any more, not much.
Old Sep 30, 2006 | 09:15 PM
off topic, i have a rattle i couldnt find forever! found it. it comes from the rear drivers window...wierd. it at the top of the window where it seals. it comes and goes but mostly stays! maybe your is there also!
Old Sep 30, 2006 | 09:19 PM
KyleT's Avatar
i think my rattle is the seat back latches, but im not sure, it doesnt move, but there is a rattle right there in the c-pillar area.
Old Sep 30, 2006 | 09:45 PM
d0ubledown's Avatar
where on the rear bumper is it hitting? mine slightly rubs on the mudflap where it bolts to the bumper inside the fenderwell. not enough to worry about...but i do want to change those bolts to flathead screws or something. once i get my custom bumper built..the mudflap/flare piece wont be an issue anymore. also i have a 1.5" BL..so that may account for a bit more clearance too...
oh..and if you want to try to stuff your full size spare..you could try cutting a bigger arc off the bottom lip of the bumper. i can fit an inflated 33" spare..but it doesnt sit properly against the X-member as the stocker spare did..so i just tighten it down with ratcheting tiedown straps. thats only when im campin and the trunk is stuffed. otherwise, on wheeling trips its in the trunk, and in the garage the rest of the time
EDIT: truck looks great btw those 295's look significantly bigger...
Old Sep 30, 2006 | 10:01 PM
KyleT's Avatar
i jacked this pic, but it is rubbing on the edge of the bumper. near the bolt hole things there... like a bad rub. it must be fixed before i go next weekend.
TheBFA
Feb 15, 2020 06:55 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Flightguy
Oct 2, 2015 05:34 PM
dbollier123
Sep 29, 2015 05:23 PM
