Front End Squeak
Old Sep 27, 2006 | 03:38 PM
Matt's Avatar
Front End Squeak
I have an '02 4Runner (SR5 4x4) with Swayaway's in the front and lately I've been noticing (and so has everybody else) a squeak coming from my front end. When I brought my 4Runner to the Toyota dealer they said it was coming from the front right shock. However, when I brought it somewhere else for a 2nd opinion, they said it was the upper ball joint that needs to be replaced. Is there a way to determine who is right here? The front end squeaks whenever I'm driving over anything other than a flat surface. The dealer wants $222.00 to replace the upper ball joint. What do you guys think???
Old Sep 27, 2006 | 03:55 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
does it squeak if you have a friend rock your runner side to side? if so, try to listen and pinpoint it if possible
Old Sep 27, 2006 | 04:16 PM
Tanto's Avatar
I know that there was a factory recall on some Tacomas for this problem. Probably is on your year Runner too. The dealer can run your vehicles VIN# and tell you if it applies to yours.
Old Sep 27, 2006 | 04:20 PM
do you happen to know the years affected? my front drivers side squeaks like mad!
Old Sep 27, 2006 | 04:28 PM
Bob_98SR5's Avatar
check your sway bar bushings too.
Old Sep 27, 2006 | 04:47 PM
seanz0rz's Avatar
Guest
i have a suspension squeek (at least i think thats what it is)
when the car rocks back and forth, it squeeks,
not a huge deal to me, and ill find out what it is when i have time this winter.
Old Sep 29, 2006 | 01:21 PM
alotawatts's Avatar
Solicone
Start with some silicone spray on all of the sway bar bushings -
Old Sep 29, 2006 | 01:34 PM
boss hog's Avatar
how many miles on your swayways coils over, hemi joint on my swayways started to squeak after a few years.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
