99 3rd gen. heater core removal
Old Oct 3, 2006 | 10:56 AM
WillieP's Avatar
First time post. How difficult is it to remove heater core from my 99 4Runner? I currently have a leak coming from a small metal tube that protrudes from the firewall. Nothing is connected to it, I am assuming it is a drain. Look forward to your input.
Old Oct 3, 2006 | 11:01 AM
MTL_4runner's Avatar
That wouldn't be the drain for the AC would it?
What kind of fluid is it? Coolant? Water? ATF?
Old Oct 3, 2006 | 11:04 AM
eric-the-red's Avatar
If it's leaking clear water that'll probably be it, if it's your heater core it'll leak coolant, and the level in the system will go down.
Old Oct 3, 2006 | 12:22 PM
WillieP's Avatar
Thanks for the input. It appears clear, however it has a oily feel to it, and yes the coolant tank was low. Is this a big job to replace.
Old Oct 3, 2006 | 12:31 PM
User 051420's Avatar
This is a BIG job. I had to have mine replaced last December..TWICE..to the tune of $1500 each time. The whole dash has to come apart, and the heater box out.
Old Oct 3, 2006 | 10:24 PM
CopenHagen_Smokeless's Avatar
im currently goin to an automotive school in C.T. and i just happened to finish heating and air condisioning, if ur a/c system is a r-134 then the clear oily substance is ur PAG oil, the heater core isnt all that hard to replace but it involes takin out the whole dash, the drain is usually coming out of the fire wall in the engine compartment, the heater core box isnt hard at all its only 6 screws
the1998sr5
15
Jul 14, 2020 08:35 PM
this_guy
Jul 31, 2015 01:27 PM
Bucksnuff
Jul 31, 2015 07:09 AM
jjrbus
Jul 19, 2015 02:06 PM
msane99
Jul 17, 2015 10:13 AM
