pics needed of 3rd gen. 3"susp. and 2" body
Old Oct 3, 2006 | 07:59 AM
4runnin2's Avatar
I posted this on ttora also but it seems like I get quicker answers over here.Thanks in advance for any advice!
I searched last night for some pics of 3rd gen 4runners with a 2.5"-3" suspension lift and a 2" body lift but ended up not finding to many pics. Also if you can put in you 2 cents on ride quality I would appreciate it. So if you have some pics could you post'em or send me a few at thegper@msn.com. I am wanting to maybe go to a larger tire and was thinking how it would look with a 305/70/16 or a 315/75/16.
Thanks in advance....Bryan
Old Oct 3, 2006 | 08:06 AM
mastacox's Avatar
It will look awesome.
Case closed!
Old Oct 3, 2006 | 08:11 AM
bamachem's Avatar
you don't need that much for 305's. they're 33" in diameter. all you need is a 2" suspension lift in the front to clear them. for 315's (35's), then you'll need the same 2" of lift in the front and a 1" body lift.
1. 1.5" of suspension lift and 1" body lift in this pic with 305/70-16's on 16x8 wheels and 4.5" of backspacing. no rubbing after trimming the pinch weld on the firewall.
2. this one has an OME suspension. 2.0" up front and 3.5" in the rear with a 2" body lift. those are 285/75-16's on 16x8 wheels and 4.25" of backspacing.
3. this one has 2.0" of front suspension lift with a 1" body lift. the firewall has been clearanced along with the upper A-arms so the 315's would fit. those two things are a must to run 315's without any rubbing.
Old Oct 3, 2006 | 08:47 AM
NPE701's Avatar
Do I need to regear for 33's? And if the answer is no, what about 35's?
Old Oct 3, 2006 | 08:50 AM
Localmotion's Avatar
you dont have to regear for anything. It is recommended if you go 35s though. 33s?..that depends on whether or not you want the power back. I have 4.10s and 33's and havent regeared. Im not a throttle jockey so im not too concerned with the loss of power.
Eventaully I want to regear.
Old Oct 3, 2006 | 08:51 AM
ebelen1's Avatar
Look for Erikjeanna's rig. He has exactly what you're asking to see.
Old Oct 3, 2006 | 09:01 AM
ROOFGOOF's Avatar
Here is mine for now...different stages can be found here.
https://www.yotatech.com/forums/f79/roofgoofs-1999-4runner-71997/
I currently have about 4-5 inches all around total....soon to be close to 7.5 inches/8 inches total.
Old Oct 3, 2006 | 09:08 AM
d0ubledown's Avatar
2.5~3" susp, 1.5 BL. before and after.
not much noticable difference...on a black truck anyway haha.
305 is the same height as the 285's just wider so no added clearance needed. when i did susp and no BL i rubbed only on plastic trim parts (flare and running board@ full lock. i have FZJ80 wheels which are 4.5 or 4.75" backspacing..
what gears do you have now? ive got 4.30's and felt a power loss goin to 285's. im over that now, but wish i had lower gears on the trail. same would apply for 305's. if youre wanting 315's its alot more work. wouldnt go higher (numerically lower) than 4.56's and would definitely need alot more clearancing either via cutting, or bigger body lift..of which i wouldnt do the latter...
Old Oct 3, 2006 | 09:13 AM
lee's Avatar
lee
2.5" OMEs in rear, 2" spacers in front, 1" BL and 305/70/16's.
Old Oct 3, 2006 | 10:21 AM
BeachRNR's Avatar
Looks like 305's are the way to go. It looks alot better than the skinny 285's
Old Oct 3, 2006 | 10:59 AM
4runnin2's Avatar
Yeah. I have 285's now. I want a little wider and maybe taller If I can get away with it!
Old Oct 3, 2006 | 11:05 AM
bamachem's Avatar
295's would be another good choice. 295/75-16's are ~34" tall and approximatley 11.5" wide compared to the ~33" height 11" width of the 285's and the ~33" height and 12" width of the 305's. i know Nitto makes a Terra Grappler in that size...
Old Oct 3, 2006 | 11:20 AM
as does BFG ATs
Old Oct 3, 2006 | 12:02 PM
4runnin2's Avatar
I like that Idea. I'll have to check on the BFG at's and see what kind of deal I can get. Now hopefully I can sell my 285's to offset some of the cost of doing this.LOL
Bryan
Old Oct 3, 2006 | 01:31 PM
HarrisonP's Avatar
Before with 3" in front and OME's in rear
After with 3" front and LC coils in rear + 2" body lift
Old Oct 3, 2006 | 01:37 PM
KyleT's Avatar
i put on 295's and have a 1" body lift and have rubbing issues on my rear bumper and barely on the pinch weld in the front.
Old Oct 3, 2006 | 01:42 PM
KyleT's Avatar
Old Oct 3, 2006 | 02:45 PM
4runnin2's Avatar
Harrison,Does your truck feell like it has alot of bodyroll with the 285's on it?
I like the stance of kyles rig alot. The Lexus rims are 4" backspacing right?
Old Oct 3, 2006 | 03:16 PM
HarrisonP's Avatar
I can feel the body roll, but it doesn't bother me that much. I am a very easy driver on the road and it handles fine off road with the stuff we have around South Carolina. I am definately going for some larger/wider tires in the near future.
Old Oct 3, 2006 | 04:12 PM
4runnin2's Avatar
bamecham, What all is involved in clearancing the firewall for the 315's. I already have total chaos upper arms and AR Teflon rims w/4.5" back spacing. I am leaning towards maybe the Pro-comp extreme all-terrains(Kind of a mix between the muds and regular all-terrains). I also noticed the runner in the 3rd pic only had a 1" body lift. Would a 2" mean less to worry about on the firewall?
Thanks,Bryan
