pics needed of 3rd gen. 3"susp. and 2" body
Old Oct 3, 2006 | 07:26 PM
grimpy's Avatar
Please show pics of how much pinch weld trimming was required to fit 33x12.5's with only a 2" lift... I'm not debating whether it would work or not because with enough trimming, anything is possible... Just want to know the extent of how much cutting is involved...
Old Oct 3, 2006 | 07:31 PM
terryjmatthew's Avatar
I cut my pinchweld back almost even w/ the firewall and don't have any clearance issues w/ 285's and 2" lift. I will try to get some pics for you when I get my truck back.(Tomorrow or Thursday)
Old Oct 3, 2006 | 08:07 PM
4runnin2's Avatar
I don't have any rubbing with the Donahoes in the front and 285/75/16's Tires. It may be because I have aftermarket rims though?
Old Oct 3, 2006 | 10:50 PM
ErikJeanna's Avatar
Not sure if you are still in the market for pics, but here is my rig with 3" suspension and 2" body.
My front end clearance after some trimming with a Dremel (before 2" BL):
And after shaving the lower valence (before 2" BL):
Body lift install... the left side (of the pic) is finished, now onto the right:
All finished
All dressed up and ready to roll...
Old Oct 4, 2006 | 02:50 AM
  #25
4runnin2's Avatar
Eric is your truck only 2wd? I have alot more clearance with the 285's and Donahoes in the front than what you are showing you had without the BL.
I am assuming the 2wd's have a lower stance?
Old Oct 4, 2006 | 03:25 AM
  #26
grimpy's Avatar
The only lift that would make a difference is a spacer lift... The coils/coilover 2wd & 4wd lifts are the same.
Old Oct 4, 2006 | 04:31 AM
  #27
turboale's Avatar
2.5" suspension w/ 285s and sagging front coils from the TJM...
Coilovers +2" Body Lift w/ 285s
Old Oct 9, 2006 | 07:46 PM
  #28
4runnin2's Avatar
Thanks alot for the reply's guys. I ordered a 2"body lift from 4crawler. I will install it and see how I like my 285's with it. I'll post pics when I get it done and get your opinions on wether I should go bigger.
Bryan
Old Oct 9, 2006 | 08:53 PM
  #29
KyleT's Avatar
Harrison,Does your truck feell like it has alot of bodyroll with the 285's on it?
I like the stance of kyles rig alot. The Lexus rims are 4" backspacing right?
no, i have 1.5" wheel spacers on it. they are like 4.5 or something. have to run fronts all the time and rears when i wheel to clear the body when it stuffs.
Old Oct 13, 2006 | 09:18 AM
  #30
Finally got around to taking some pics. Figured I would share them.
** pinch weld pics, pinch weld mod **
Old Oct 13, 2006 | 11:14 AM
  #31
4runnin2's Avatar
Terry you are running 315's?. Do you have a pic of how the truck looks from a distance?
Bryan
Old Oct 13, 2006 | 11:27 AM
  #32
bamachem's Avatar
bamecham, What all is involved in clearancing the firewall for the 315's. I already have total chaos upper arms and AR Teflon rims w/4.5" back spacing. I am leaning towards maybe the Pro-comp extreme all-terrains(Kind of a mix between the muds and regular all-terrains). I also noticed the runner in the 3rd pic only had a 1" body lift. Would a 2" mean less to worry about on the firewall?
Thanks,Bryan
http://www.sonoransteel.com/thirtyfive.html not really. the trimming needs to be done either way. with a 1", you just sit 1" lower and have a 1" lower COG.
Old Oct 13, 2006 | 11:47 AM
  #33
Fink's Avatar
I've got a '99 with the Tundra/OME setup, I belive it's about 2 or 2.5" of lift and I had to trim a little bit off the front valence but nothing major. I am probably going to upsize to the 305's the next time I get tires but I am not going to install a body lift. So I will need to do some trimming for sure.
I think the Tundra/OME by itself is enough but sometimes it would be nicer to be a little bit higher up. This is working fine for me.
Good luck.
Fink
Old Oct 13, 2006 | 12:31 PM
  #34
Bryan
No, I am running 285/75R16's w/ 2" of lift. Nice and low and no rubbing.
Old Oct 14, 2006 | 04:38 PM
  #35
HOJU's Avatar
Here's a pic of mine..... 3" Susp, 2" BL w/35x12.50r17's
Old Oct 14, 2006 | 04:52 PM
  #36
ecchamberlin's Avatar
Allen
Betsy is a mean looking rig! How do you like the back spacing of those Tundra rims? Any a-arm rub or are you using spacers?
Old Oct 14, 2006 | 04:55 PM
  #37
Localmotion's Avatar
Originally Posted by ecchamberlin
Allen
hes running aftermarket a-arms.
betsy sure does look puuurdy
Old Oct 14, 2006 | 05:08 PM
  #38
4runnin2's Avatar
Hoju,
Your truck looks badazz. I am doing the pro-comp xtreme all-terrains (315/75/16's buy 3 get one free!). I am waiting for the 2" body lift, Should be here on Monday or Tuesday. Get the tires put on after that and hopefully be rolling again by the weekend!
Old Oct 15, 2006 | 04:08 PM
  #39
86toyotakid's Avatar
man Hojo u are really inspireing me to run your lift setup thoes 35s make your rig look sweet.
Old Oct 15, 2006 | 05:52 PM
  #40
HOJU's Avatar
Thanks guys.... Betsy has been good to me over the years.
Eric- I love the Sequoia wheels, they've got 5" backspacing, therefore I've got Marlin Crawler 1.25" spacers. I've also had ATS a-arms since "phase one" of my lift.
4runnin2- Hope all goes well with your setup! let us know-
Team420
Jan 12, 2021 04:57 PM
6th Gear
19
Dec 10, 2019 07:31 AM
BigArt70
Jun 30, 2015 09:51 PM
HALMAN
Jun 14, 2002 09:02 PM
