Fuel injector HELP
Old Oct 30, 2011 | 12:16 PM
peter1612's Avatar
Fuel injector HELP
I have just replaced injector number 4 my problem is that I have tried to set the fuel rail twice and each time I am leaking fuel am I not setting the rail right is there a trick to setting the fuel rail All help would be greatly appreciated As it is a lot of work getting to the fuel rail each time
Peter
Old Oct 30, 2011 | 06:04 PM
A.Wilson013's Avatar
Where is the fuel leaking from? I imagine you're probably pinching one of the o-rings... Or forgot to install one of them....
edit*** Message DeathCougar and Vital22re hundreds of times about this. Maybe they have a few tips on how to take off the rail more quickly, since they have done it so many times.
Old Oct 30, 2011 | 06:17 PM
vital22re's Avatar
totally a bro
don't force the injectors. lube the o rings with vasoline and spin the injectors into place. This keeps the o rings from pinching.
Old Oct 30, 2011 | 06:19 PM
So today we learned....
-Don't force it
-Use plenty of lube
-Spin it in ( I will have to work on that)
Old Oct 30, 2011 | 06:21 PM
DeathCougar's Avatar
Little lube goes a long way
Old Nov 1, 2011 | 04:37 AM
peter1612's Avatar
Hey
So I took all the advice given replaced all o rings used the lube and made sure I din not over torque the fuel rail bolts and YES no leaks THANKS TO ALL WHO REPLIED
Peter
Blamalam
Mar 12, 2022 07:34 AM
RatOmeter
Oct 22, 2015 03:17 PM
Tacoma1313
Aug 17, 2015 05:44 PM
pyramid
Jul 30, 2015 10:05 AM
HookahRoo
Jul 20, 2015 07:06 PM
