transfer case compatibilty
Old Oct 3, 2011 | 01:38 PM
khann's Avatar
hi Yoters
Im trying to make my yota 4R 96 LTD get back to 4wd enable - i can buy whole Tcase but from younger version 2001. Will it fit how is 4wd computer connection possibility? has anyone tried to do this?
thanks for any efforts.
regs khann
Old Oct 3, 2011 | 02:20 PM
BLKNBLU's Avatar
I think it is not the way to go. I don't know if it is impossible but probably not desirable. There was a change in t case actuation in the '01-02 runners. See number 7 here: http://www.top4runners.com/runhist/runhist32001.html
Also, a friend of mine had issues with his due to electronics here:
https://www.yotatech.com/forums/f66/...re-4wd-152798/
I believe he got it fixed but it has been a recurrent problem to the point that he is trying to go the other way as you. (i.e. put in a 96-00 t case) Not sure if he got that done or not, I just know it was something he was working on.
Good luck.
Old Oct 3, 2011 | 02:27 PM
DeathCougar's Avatar
96-98 Limited is the case you want. 99+ cases are longer, so you may have driveline issues. You will also have electronic issues with the actuator, among other things.
Old Oct 3, 2011 | 02:39 PM
khann's Avatar
yay thanx gents.
its kinda hard to buy 4R parts in europe but i keep trying - my T is worth it
in my 4R electronic actuator is present and not working....tried to put other from 99 but they are not compatible and parts inside actuator completely different
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Phantez
Sep 30, 2015 08:24 AM
Toys4parts
Sep 26, 2015 01:56 PM
