12v Power Outlets/Cig don't work?!
Old Oct 20, 2011 | 08:40 AM
aviator31's Avatar
Ok, looked up some prior threads, but this one has me stumped. On my bro's 99 Limited his Cig lighter and front 2 12v outlets don't work. BUT, the rear 12v works just fine. Does this mean that all 3 in the front need to be replaced because the "internal fuse" is blown in them??? Thanks in advance!
Old Oct 20, 2011 | 09:00 AM
TheDurk's Avatar
Probably, unless the PO modified the rear outlet to a separate full time connection. Time to get your test light and test the 12V+ wires to each socket rather than asking the internet. Pulling the center fascia takes about thirty seconds if you've done it a few times.
Somewhere there is a how-to on bypassing the fusible link. People had non-protected sockets, relying just on the fuses, for a long time, but obviously you are incurring some additional risk.
Old Oct 20, 2011 | 09:08 AM
MKtaco_98's Avatar
I had this same problem mine turned out to be the fuseable link on the back of them had melted
https://www.yotatech.com/forums/f2/9...-wires-213880/
Old Oct 20, 2011 | 11:40 AM
drkblu4runner's Avatar
bypass the fusible link. i just soldered a wire in place of the "fuse" on the back of the socket
Old Oct 20, 2011 | 12:20 PM
Corey's Avatar
Co-Founder/Administrator
I had to do this on my old '90 Xtracab.
A compressor blew the link.
I do not see a reason for that link as long as the line has a fuse for it.
Yota.Jay
Mar 6, 2016 11:02 PM
aciorba23
Jun 29, 2015 04:18 PM
rbravo1
Jun 29, 2015 01:34 PM
toy89yota
Jun 24, 2015 01:18 PM
gog1968
Jun 22, 2015 05:55 AM
