Valve cover washer seals
Old Mar 28, 2005 | 02:01 PM
ttr125mar's Avatar
Hey, I just got done putting a new valve cover gasket on and new valve cover washer seals but the problem is I can't get the bolt to over pass the washer seal its flat even with it. Should I try and smash the washer seals down? I tried pounding the the gasket done but no luck. Also would it hurt to smash the washer seals in a vise?
Thanks,
Mario
Old Mar 28, 2005 | 02:24 PM
fadetoblack72's Avatar
Don't get what you mean. Will they slide onto the studs?
Old Mar 28, 2005 | 02:25 PM
ttr125mar's Avatar
Ya they fit perfect but the bolt doesn't pass the washer so I can't get the nut on the bolt.
Thanks,
Mario
Old Mar 28, 2005 | 02:27 PM
Hmmmm. How long are the studs? You should have plenty. Maybe your cover gasket needs to be pushed in a little more
Old Mar 28, 2005 | 03:06 PM
PirateFins's Avatar
Make sure the cover is fully seated to the head. The raised portion of the washer goes down into the hole of the cover. Don't smash the washers nor over tighten them that can cause the top of the rocker arms to hit the cover. They need to be tourqed to 52 in/lbs.
All else fails post a picture so we can see what the problem looks like.
Old Mar 28, 2005 | 03:41 PM
ttr125mar's Avatar
Alright will try, also the cover isnt touching the head because of the new gasket in it, is there a way to smash it down so it is touching? I tried using a rubber mallet but that was no use at all.
Thanks,
Mario
Old Mar 28, 2005 | 03:46 PM
PirateFins's Avatar
Thanks,
Mario
What I meant was no large gaps betwwen the head and the cover. Don't smash it down.
Also try and seat the washers a little farther on the studs by turning them like you are screwing them down.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
keithporter83
Jul 18, 2015 12:37 PM
