shaky hood
Old Mar 31, 2005 | 09:44 AM
blarson's Avatar
shaky hood
I have a 91' runner and every time reach about 80 mph or drive in high winds my hood starts to shake. I am sure that it is nothing serious but it seems a little excessive. I took a look under the hood and it seems that the actual hinges are behind the firewall. Does anyone have any experience with this??
Old Mar 31, 2005 | 10:11 AM
roger's Avatar
My '98 Tacoma does that a little bit too. I think it's just the way they are designed. It is a truck after all. I just ignore it.
Old Mar 31, 2005 | 11:15 AM
Jason B's Avatar
Do you have a bug shield on it? That will definitely cause it.
Old Mar 31, 2005 | 11:24 AM
rimpainter.com's Avatar
Have you checked the hood adjustment grommets/screws at the front upper crossmember (by the headlights)? If not, make sure those are not too far down, they can cause excessive flutter too.
But I agree with what's been said, a bug shield causes more hood flutter. Mine is annoying, but only if I stare at it, and at 80+MPH, I should be looking elsewhere
Old Mar 31, 2005 | 12:58 PM
AZ4ME's Avatar
[QUOTE=<96 Runner>]Have you checked the hood adjustment grommets/screws at the front upper crossmember (by the headlights)? If not, make sure those are not too far down, they can cause excessive flutter too.
This is what helped my hood at high speeds.
Old Apr 1, 2005 | 09:21 AM
blarson's Avatar
Thanks for the info. I do have a bug shield i am sure that that contributes. I adjusted those grommets for the hood as well, it helped. Thanks for the help.
Old Apr 1, 2005 | 09:31 AM
Jason B's Avatar
Yes, mine never did it until I added it. Also, that shield reduces your MPG by at least 1 mpg.
Old Apr 1, 2005 | 09:47 AM
I didn't lose 1 MPG when I put mine on at 83K miles. Where did you get that information?
I keep track of my MPG on charts, so I am going to have to go back and review that. I do remember a slight loss, but I thought that was from my 4.30 gears that I switched to at the same time.
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
Davebarbier
Nov 3, 2015 03:28 PM
BimmerSage
Sep 17, 2015 11:48 PM
