Quick question on manual hubs
Old Apr 6, 2005 | 04:43 AM
bryanr's Avatar
I just purchased a set of manual hubs off e-bay for my 89 4X4 w/IFS. Is there anything else I need to buy to install these or should this be everything I need? If there is something else, got a link to it please?
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Thanks!
Bryan
Old Apr 6, 2005 | 04:55 AM
AW1090's Avatar
That should be it other than the gaskets....check these out
https://www.yotatech.com/~corey/tech...etal22lica.htm
http://www.4x4wire.com/toyota/maintenance/front_end/
I think one of the threads on 4x4 has the part numbers for the gaskets as well...it's not hard, but have fun with the cone washers. hose them down with some pb blaster ahead of time.
Old Apr 6, 2005 | 05:12 AM
Jared Ajlouny's Avatar
are you switching to manual hubs?
Old Apr 6, 2005 | 06:55 AM
leiniesred's Avatar
going from auto hubs? You'll want a set of standard wheel bearing nuts and the lock tab ring between them too.
Old Apr 6, 2005 | 07:12 AM
bryanr's Avatar
Yes, that's the plan!
Old Apr 7, 2005 | 07:42 AM
bryanr's Avatar
Any links to what exactly I need to order? Thanks.
Old Apr 7, 2005 | 08:00 AM
kyle_22r's Avatar
10 bucks says you have ADD, not auto hubs. auto hubs look like a manual hub without a dial, and you need different spindle nuts or something like that to convert over. ADD is just a drive flange and a vacuum disconnect front end.
Old Apr 7, 2005 | 08:44 AM
AgRunner06's Avatar
If it's just ADD, he doesn't need the nuts and locking washer. All he'll need is the gaskets and some anti-seize.
Old Apr 7, 2005 | 09:39 AM
bryanr's Avatar
Are the gaskets something I could pick up at a store like Parts America?
Old Apr 7, 2005 | 10:36 AM
AW1090's Avatar
pick them up from your local stealer....check those links I posted up top they should be a good read for you and also help for rebuilding later on
Old Apr 7, 2005 | 11:12 AM
AgRunner06's Avatar
Yeah you'll probably only be able to get them from the dealer but you can try. Mine were a whopping $12.
oldirtydirt
Feb 23, 2020 09:30 AM
PlayAwhile
Jul 20, 2015 11:36 AM
icentropy
Jul 14, 2015 10:23 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
ItsJustD
Jul 7, 2015 07:49 AM
