high flow cat worth it?
Old Mar 29, 2005 | 06:30 PM
89macrunner's Avatar
would it be worth it for me to do a header back exhaust with a magnaflow high-flow cat? Im already planning a cat back with a flowmaster and i figure it cant be much more money for the pipe from the header. im thinking its gonna cost me a good $300 for all of the pipes and another $100 to get the muffler and cat here so is the $400 worth the new exhaust system?
Old Mar 29, 2005 | 06:38 PM
waskillywabbit's Avatar
LC header and high flow cat w/ new exhaust system, Delta 40 series flowmaster...at least I sound good now!
Definitely worth it!
Old Mar 29, 2005 | 06:53 PM
AW1090's Avatar
what!....where are you getting the headers from? I spent about $165 on a delta flow s.s. 50 series and high flow cat. I thought any of the good headers for the 3.0 were around $500
Old Mar 29, 2005 | 07:09 PM
dwh91102's Avatar
I think I have some where around $600 invested from header (downey) to tip
Old Mar 29, 2005 | 07:16 PM
Tomsriv
Guest
Posts: n/a
A cat back is pretty pointless for any car. Unless you have good flow the whole way through then a cat back won't help much. A header is a good idea, but you could save money on the cat by buying a universal fit V8 cat since its designed for higher flow.
Old Mar 29, 2005 | 07:50 PM
rimpainter.com's Avatar
Care to back these claims up with some numbers?
Old Mar 30, 2005 | 08:19 AM
4Crawler's Avatar
I think you'll find most all cats are now "high flow" designs. That term came about in the early days of cats. The early cats used beads then a new and improved honeycomb design came out that was less likely to clog up and that flowed exhaust better. So those cats were advertised as "high flow". I've looked at a few different Toyota cats and they are all essentially the same inside. All stainless steel, all honeycomb matrix and they all look like they would flow equally as well. You can play around with putting a larger cat on or one with larger inlet and outlet pipes. That is probably all the current "high flow" cats are anyway. If the old cat is not plugged up, may as well run it until it is shot then replace it.
Old Mar 30, 2005 | 12:32 PM
jimbo74's Avatar
also dont know the laws where you live, but here in CA you cannot remove the cat if it isnt bad or has so many xxx amount of miles on it, if you do, you face jail time and/or a huge fine....
Old Mar 30, 2005 | 12:44 PM
4RUNR's Avatar
Guest
What criteria is there to make it worthy? Pass inspection? $/per HP? Joy from having something new welded to the truck?
Old Mar 30, 2005 | 01:25 PM
William439's Avatar
I am going to have to agree with 4crawler. Unless your Cats are shot, don't replace them. The power gains and sound comes mostly from the headers and the exhaust. If you are going for power save the money on the cats and buy a high flow filter or wider throttle body, you will see more power from them than you ever will from a new cat. Unless of course you have already done those things, and have money to blow, then go with some high flow cats.
Old Mar 30, 2005 | 05:46 PM
gwhayduke's Avatar
Originally Posted by ace
on your model year you can gut the converter without effecting anything.
you may have to run plus though and it frees a lot of tourque and ponys
Here we go again....
RatOmeter
Oct 22, 2015 03:17 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
