Rear ARB Question
Old Jun 2, 2004 | 11:40 AM
NVRSASTK's Avatar
Rear ARB Question
Has anyone ever had trouble with there ARB they installed in the rear? Meaning: Broken Axles, Drive Shaft, Etc. Anything to look out for
Old Jun 2, 2004 | 12:19 PM
keisur's Avatar
not me.
Old Jun 2, 2004 | 12:20 PM
Ducky's Avatar
Not me... so far... *knock on wood*
Old Jun 2, 2004 | 04:04 PM
shazaam's Avatar
not me
Old Jun 2, 2004 | 06:07 PM
mt_goat's Avatar
Originally Posted by sdastg1
not me
No problems yet, front or rear.
Old Jun 2, 2004 | 10:10 PM
smr4runner's Avatar
Nada dude.
Old Jun 3, 2004 | 03:30 AM
Bratik's Avatar
no problem
Old Jun 3, 2004 | 06:56 AM
GRNTACO's Avatar
Zip
Old Jun 3, 2004 | 10:10 AM
Nitro Hotpants's Avatar
Nope, no problems whatsoever
Old Jun 3, 2004 | 10:37 AM
bamachem's Avatar
How much did you pay for your lockers and compressors?
Old Jun 3, 2004 | 10:57 AM
calrockx's Avatar
i just got some prices today. lockers go for $650, the air compressor $220. you're lucky you got such a good deal. i'm doing it the non-deal way
the problem that comes up with arb air lockers seems to be leaks. but i hear if you have the install done right and keep up with regular maintenance, you should be good.
Old Jun 3, 2004 | 11:06 AM
bamachem's Avatar
That's good to know... For some reason, I was thinking that the Locker + compressor was $650. That is a sweet deal at $500...
Old Jun 3, 2004 | 01:20 PM
keisur's Avatar
The only leak I've seen is the plastic air line for the front locker. It gets jambed against the oil pan and kinks and then leaks after a while. I installed and bent the ferule thing-a-ma-bob inside the tubing and haven't had it happen yet a secind time. Iif you get the heavy duty SS air line you should have that problem. If you use the plastic stuff, make sure you reinforce it where it rubs on sharp edges and keep it away from hot stuff.
Old Jun 3, 2004 | 06:11 PM
RTdawgs's Avatar
no problemo
Old Jun 3, 2004 | 06:20 PM
Flygtenstein's Avatar
Two CV's in front.
No issues in the rear.
I don't think there are many issues in the rear since that usually comes with uber wheeling. Likely not an issue.
Old Jun 3, 2004 | 06:32 PM
george16's Avatar
No problem.
George
Old Jun 4, 2004 | 06:40 AM
mt_goat's Avatar
Originally Posted by Flygtenstein
Two CV's in front.
What happened with the cv's? Did you have a lot of angle on them? Were they stuffed or drooped when they broke?
Jun 1, 2021 01:51 PM
nick9455649
Sep 11, 2015 05:10 PM
icentropy
Jul 14, 2015 10:23 AM
A2theK
Jul 12, 2015 10:46 AM
87turboPA
Jul 9, 2015 05:58 AM
