2nd Gen Exhaust and rear window problem
Old Jun 2, 2004 | 03:30 PM
tman6508's Avatar
Does anyone have a website where I can listen to different exhausts on my 4runner? I have a 1994 4runner bone stock, and I thought I saw a website on here a couple weeks ago, but I can't find it.
Also, just yesterday I rolled down my back window it it came out of the tracks or something and I had to pull it back up by hand while i was using the key to get it all the way up. Has anyone had this happen, and how hard is it to fix?
Thanks,
Travis
Old Jun 2, 2004 | 06:30 PM
Corey's Avatar
Co-Founder/Administrator
That would be my website, and it's listed on my homepage, and perhaps in my sig file.
It's also listed in the Community section under the link "YotaTech on the Web."
Can not help you on the window, but I'm sure others can.
Welcome to YotaTech
Old Jun 3, 2004 | 02:48 PM
ed's Avatar
ed
On the rear window: not difficult and the parts are cheap. What tends to happen is there's metal channels/guides that rust on the bottom of the glass that the motor arms move in. Pulling off the int panel on the hatch you should be able to confirm. The new guides can be a PITA to install - I tried all the tricks and finally just bent open the channel more. Seemed to work. The glass installer said they bend out the sides till it slides on easily then glue everything together with a slow setting glue. (Had to replace the window itself after it got busted a few wks later by some bored kids.)
Old Jun 3, 2004 | 04:02 PM
tman6508's Avatar
Thanks corey and ed!
warrenjcarlson
Jul 22, 2016 11:47 AM
voiddweller
19
May 2, 2016 09:10 PM
Corey
Jun 19, 2002 11:06 AM
