? on draining rear diff fluid
Old Jun 8, 2004 | 06:31 AM
ElwayLite's Avatar
From the drawing I saw it looks like just any other gear drive, open the fill/breather at the top then open the drain at the bottom. Close the drain the refill. Am I way off or is that all there is to the process on a yota?
Old Jun 8, 2004 | 07:21 AM
Designsbyme's Avatar
That's it.
Old Jun 8, 2004 | 07:23 AM
ElwayLite's Avatar
Thanks. It looked just as simple as the gear drives we have at work but honestly I couldnt believe something on a vehicle was designed that simple, its usually the other way around.
Old Jun 8, 2004 | 08:00 AM
Bob_98SR5's Avatar
elway,
yeah, simple as that. see my write up: http://www.4runners.org/articles/difftsf
you'll need a hand pump, preferably the kind that can screw onto the top of the bottle.
bob
Old Jun 8, 2004 | 08:03 AM
Robinhood150's Avatar
Not the breather, there is a dedicated plug for filling on the back of the diff. If you fill to the breather it'll be way too high.
Old Jun 8, 2004 | 08:08 AM
ElwayLite's Avatar
Got is guys, thanks. Bob the writeup is great. I was calling the fill plug the breather, didnt notice if there was a third plug higher or not but we were talking about the same one I was just referring to it incorrectly.
Old Sep 12, 2006 | 09:04 AM
kcebes's Avatar
Good thread. I'm changing mine tomorrow.
yes. i know this thread is old but i figured i'd bump it since everyone is wheeling all summer and changing diff fluid is important!!
Old Sep 12, 2006 | 09:30 AM
calrockx's Avatar
easy fo sheezy.
i just changed mine. diffs and tcase.
Old Sep 13, 2006 | 08:02 AM
4Crawler's Avatar
Just make sure you can remove the fill plug before removing the drain plug!
Old Sep 13, 2006 | 08:12 AM
OutdoorLiving's Avatar
Diff fluid reeeeks and won't come out of your clothing! Make sure to dress accordingly.
Old Sep 13, 2006 | 01:24 PM
surf4runner's Avatar
make sure you put the drain pulg back in before refilling!
Old Sep 13, 2006 | 03:05 PM
kcebes's Avatar
Changed mine today. Yay! Tomorrow i'm doing transfer case and front diff.
Old Sep 13, 2006 | 03:13 PM
fireteacher's Avatar
please tell me what size torx (spell?) socket it is. i forgot to look when i did mine today at the local auto hoby shop!
shaun
Old Sep 13, 2006 | 03:24 PM
calrockx's Avatar
96-98: 10 drain, 12 fill
99-02: 12 both
Old Sep 13, 2006 | 03:55 PM
CyMoN's Avatar
i use compressed air in the fill hole to blow out some of the oil and gunk.
the next time i do my dif oil i am going to do it after a good drive to warm it up some.
jasonty
41
Dec 23, 2018 01:00 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
kcaudill
Jul 20, 2015 12:06 PM
Poncho0206
Jul 10, 2015 06:21 PM
