Power Loss problem
Old Jun 2, 2004 | 10:50 PM
LL's Avatar
LL
Power Loss problem
Hey guys, I notice that when i go uphills and sometimes on flat surfaces.. the truck doesn't want to go any faster than im going, if i go from 80km/h to 100km/h and from there it doesn't want to go any faster, i floor it and it doesn't want to move. It feels like its gonna go faster, then dies down. Could this be a problem with the transmission or flywheel? Sorry i didn't explain it properly, but hopefully somebody will understand what im trying to say.
98 4runner limited
Old Jun 2, 2004 | 11:55 PM
Yoter's Avatar
Guest
How often do you tune up your engine? I say you have an engine miss.
Old Jun 3, 2004 | 05:08 AM
98 Joes's Avatar
Fuel filter getting clogged? Does it run rougher when this happens or just won't go any faster?
Our avatars almost are mirror images.
Old Jun 3, 2004 | 08:14 AM
humanoid's Avatar
Clogged injectors maybe or you may need to change out the fuel filter. A tune-up may be in order as well.
Old Jun 3, 2004 | 08:15 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Has this just begun to occur? Could be an existing problem compounded by a bad tank of fuel.
Old Jun 3, 2004 | 11:00 AM
LL's Avatar
LL
well, i had a problem with the starter before, that it kept trying to start the truck while its already started, had that replaced.. and a mechanic friend of mine said it might be the tranny giving you problems now, had toyota take a look at it, they said the truck is normal... im getting a tune up done next week, ill take a look at the fuel filter. Any more suggestions? thanks for the help guys!
Old Jun 3, 2004 | 11:10 AM
rimpainter.com's Avatar
How long have you owned the rig?
Get a diagnostic done and see if any codes are stored. Sounds like the infamous MAFS problem to me.
Old Jun 3, 2004 | 11:58 AM
LL's Avatar
LL
MAFS problem?
Do you have a link with information about this?
Thanks!
Old Jun 3, 2004 | 12:18 PM
How long have you owned it?
Old Jun 3, 2004 | 12:51 PM
LL's Avatar
LL
a little over a year, haven't done a tune up or anything.. just regular oil changes, got the alternator replaced and the starter
101,000 km
Old Jun 3, 2004 | 12:52 PM
Do you have autozones up there?
Old Jun 3, 2004 | 01:30 PM
LL's Avatar
LL
no we dont
we have shop kind of like it
called canadian tire
Old Jun 3, 2004 | 01:48 PM
Will they pull codes for free?
Old Jun 3, 2004 | 01:58 PM
LL's Avatar
LL
i doubt it.. ill call them
will there still be codes? there is no check engine light
Old Jun 3, 2004 | 03:12 PM
Sometimes codes are stored despite the lack of a CEL. Let us know.
BTW. The fuel filter is really easy and should be done anyway. I doubt that is the cause, but I thought I would mention it.
Old Jun 7, 2004 | 09:51 AM
LL's Avatar
LL
Hi guys, Canadian Tire doesn't pull codes for free, so what I thought I should do is take it to Toyota and get them to check out everything (a full diagnostic) on the truck. Do you think thats a good idea?
Also about my starter issue, do you think that when it was cranking the starter (even if the truck was on) constantly it would wreck something else? eg. Tranny, etc etc.
Thanks for the help!
Old Jun 7, 2004 | 10:00 AM
lee's Avatar
lee
i had a problem with my mass airflow sensor (MAFS) recently. i was on the highway doing 70, and getting it up to 90 to get in the fast lane was a chore.. it hesitated a couple times, or would suddenly burst forward at last. this also happened at lower speeds going between like 25 to 40.
get that checked out.
Old Jun 7, 2004 | 10:01 AM
lee's Avatar
lee
i forgot how much power and torque the 3.4 can generate... since i got that MAFS problem sorted out, its performed like a dream.
Old Jun 7, 2004 | 10:10 AM
LL's Avatar
LL
Thanks for the feedback lee, ill have that checked out.
Im still wondering about the starter issue? Would that affect anything else?
Old Jun 7, 2004 | 10:14 AM
lee's Avatar
lee
by the way, if you bought any kind of extended warranty, make sure you check if the MAFS is covered if it needs replacing. turns out the warranty i bought covered it, saving me around $250 to 300 bucks.
