How often do you use BG44K or other fuel system cleaner?
Old Jun 2, 2004 | 05:53 PM
redvet's Avatar
My PreRunner is running great.
Premaintenace dose now?
Every 5000 miles?
When she starts running rough?
Old Jun 2, 2004 | 05:59 PM
WT's Avatar
WT
Every 5000 miles?
I try to toss in a bottle once every 6 months or so.
Old Jun 2, 2004 | 06:22 PM
I usually use a can once every 6 mths. This is usually before I do the annual oil change and and the 6 mth mark when I change the oil filter. As one might guess - I'm using Amsoil.
Andrew
Old Jun 2, 2004 | 06:31 PM
mt_goat's Avatar
I used one bottle after 100,000 miles.
Old Jun 3, 2004 | 04:24 AM
redvet's Avatar
Interesting!
6 months or 100,000 miles.
Old Jun 3, 2004 | 04:36 AM
98 Joes's Avatar
About every 4 to 6 months (I'm anal about clean injectors). I use the Chevron Techron, it seems to work well. I was burning only Chevron gas also until it $2.50.
Old Jun 3, 2004 | 08:03 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
I pour a system cleaner in the tank every 10-12,000 miles. That works out to every 4-6 months for me.
Old Jun 3, 2004 | 08:23 AM
toy283's Avatar
I pour in a bottle of the Chevron stuff every oil change, so 3-4 times per year.
Old Jun 3, 2004 | 08:31 AM
AznSky's Avatar
so what exactly do you do with this stuff? just pour the whole container in your gas tank before you fill up? Or do you pour some, then add some gas, and then pour some, back and forth?
Old Jun 3, 2004 | 08:35 AM
toy283's Avatar
I always pour it into the tank right before I fill up. Allows the stuff to thoroughly mix with the gas. Probably not really an issue, it'll mix either way.
Old Jun 3, 2004 | 08:45 AM
X-AWDriver's Avatar
I use BG's 44K about every 12-15k miles.
Old Jun 3, 2004 | 08:50 AM
AznSky's Avatar
Cool, and it's just basic injector cleaner that you can get anywhere? Or should I special order the BGK stuff I'm reading so much about
Old Jun 3, 2004 | 09:28 AM
X-AWDriver's Avatar
I actually get BG's through a dealer for about $18 a can while Pep Boys wanted over $20 a can.
I don't mind paying a little more since I know the stuff works.
Old Jun 3, 2004 | 10:58 AM
bbkoz's Avatar
I run 1/3 a can of seafoam through the Intake once a year, and throw the rest of the can in the gas tank. That's around every 15,000 miles for me.
Old Jun 3, 2004 | 02:26 PM
redvet's Avatar
I believe I read forum member Tor sells BG44K for just under $15 a can.
Old Jun 3, 2004 | 02:45 PM
Buddyman's Avatar
Every oil change I use fuel system cleaner.
Old Feb 27, 2008 | 05:27 AM
mkgarrison5's Avatar
can you double the dosage on the bgk or should you use as noted since its pretty potent stuff?
chukarhunt
Dec 8, 2019 11:39 AM
montanatruck
Feb 26, 2017 07:07 AM
skoti89
Sep 11, 2015 07:46 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
